It seems like most people prefer RWD, but I don't get it. Why is it better? I always figured FWD was better because the weight of the engine and everything.
this is very true ... BMW was the only one who recently attempted RWD compact/subcompact .. the 1series, and its biggest problem is lack of space .. the RWD bits just rob the car of space.FoMoCo Fan said:FWD also has packaging advantages, and I beileve FWD cars are generally lighter than an equivalent RWD car. (no heavy driveline or rearend)
Sorry my friend, but neither of my STS's ('94 nd '99) were appliances. They were fast, loaded with comfort and could beat almost everyone away from a stoplight, because they underestimated how quick a Northstar FWD Caddy could be.igor said:FWD is simply for cars that are appliances.
Igor
Hrm. Correct me if I'm wrong ... the Chevrolet Chevette (compact) was RWD. If so, then I don't quite understand your quote above, igor, regarding BMW and being the only one to attempt RWD compact/subcompact.....igor said:BMW was the only one who recently attempted RWD compact/subcompact .. the 1series, and its biggest problem is lack of space .. the RWD bits just rob the car of space.
I think he said recently, and the Chevette has been dead and buried for decades now.knightfan26917 said:Hrm. Correct me if I'm wrong ... the Chevrolet Chevette (compact) was RWD. If so, then I don't quite understand your quote above, igor, regarding BMW and being the only one to attempt RWD compact/subcompact.....
Limited Slip Differentials?Tomko said:I dislike FWD.
This drivetrain layout has a habit of causing the vehicle to suddenly swing 180 degrees out of control. I call this FWD ambush. It typically happens when one drive wheel achieves substantially greater traction than the other drive wheel. The wheel with traction pulls the whole vehicle around while the wheel without traction acts as a pivot.
I've seen this many, many times, and have experienced it myself. I often see it on a highway where one wheel is on the side of the road and slips onto the gravel, or onto ice, and ka-bang before you know what hit, you are swung backwards into the ditch. I see it most often happening to inexperienced drivers.
The only way that I know around this is Stabilitrak or other similar electronic interventions.
RWD vehicles can do other crazy things, like fish-tail (or drift if you prefer) but this behavior is slower, more predictable and therefore easier to recover from. Quality tires can make a big difference on RWD.
Did they know you were racing?XP300 said:Sorry my friend, but neither of my STS's ('94 nd '99) were appliances. They were fast, loaded with comfort and could beat almost everyone away from a stoplight, because they underestimated how quick a Northstar FWD Caddy could be.
*nods*citric acid said:I think he said recently, and the Chevette has been dead and buried for decades now.
Orly?AmericanRevolution said:However, AWD is also MUCH heavier than either FWD or RWD and sucks up more gas. You also can't burning out as easily, and donuts/drifting (the "fun factor" if you like playing around or love drifting) is none. And forget about laying down a blocks worth of two rubber stripes on the pavement!, something that even FWD cars can do (albeit not nearly as easily or fun as a RWD car can...)
the Corolla was once RWD, the old Datsuns 210 and 510 was RWD too, Mazda very first GLC was RWD as well some Austins (except the Mini)knightfan26917 said:*nods*
I realize this ... it just sounded as if nobody else had done a RWD compact car ....
Cort, "Mr MC" / "Mr Road Trip", 32swm/pig valve/pacemaker
MC:family.IL.guide.future = http://www.chevyasylum.com/cort/
Models.HO = http://www.chevyasylum.com/cort/trainroom.html
"Some things just glitter and shine" ... Confederate Railroad ... 'Daddy Never Was The Cadillac Kind'
