Chevrolet Cruze Vehicle Line Specifications for Model Year 2019 show no manual transmission availability.
Rumor has it that the Chevy Colorado will also not feature a manual for MY19.
Information Source: General Motors
2019 Chevrolet Cruze Specifications
GM-EST. FUEL ECONOMY
City
31 mpg (diesel – automatic)
30 mpg (sedan – automatic)
29 mpg (sedan – Premier auto.)
29 mpg (hatch -- automatic)
28 mpg (hatch – Premier auto.)
Highway
47 mpg (diesel – automatic)
40 mpg (sedan – automatic)
39 mpg (sedan – Premier auto.)
38 mpg (hatch – automatic)
37 mpg (hatch – Premier auto.)
FUEL TANK CAPACITY
13.7 gal. / 51.9 liters (1.4L)
13.5 gal. / 51.1 liters (1.6L diesel)
ENGINE
Type:
1.4L DOHC I-4 VVT DI Turbocharged
Bore & stroke
(in / mm):
2.91 x 3.20 / 74 x 81.3
Block material:
Cast aluminum
Cylinder head material:
Cast aluminum
Valvetrain:
Dual-overhead camshafts, four-valves per cylinder, continuously variable valve timing
Fuel delivery
Direct, high-pressure fuel injection
Horsepower
(hp / kW @ rpm):
153 / 114 @ 5600 (SAE certified)
Torque
(lb.-ft. / Nm):
177 / 239 @ 2000-4000 (SAE certified)
Type:
1.6L turbo-diesel
Bore & stroke
(in / mm):
3.14 x 3.15 / 79.7 x 80.1
Block material:
Cast aluminum
Cast aluminum
Valvetrain:
Fuel delivery
Common-rail direct fuel injection
Horsepower
(hp / kW @ rpm):
137 / 102 @ 3750 (SAE-certified)
Torque
(lb.-ft. / Nm):
240 / 325 @ 2000 (SAE-certified)
TRANSMISSION & AXLE
Type:
Six-speed automatic (1.4L)
Nine-speed automatic (1.6L diesel)
Final Drive Ratio:
3.14 (1.4L automatic)
3.17 (1.6L diesel automatic)
City
Highway
FUEL TANK CAPACITY
ENGINE
Type:
Bore & stroke
(in / mm):
Block material:
Cast aluminum
Cast aluminum
Valvetrain:
Fuel delivery
Horsepower
(hp / kW @ rpm):
Torque
(lb.-ft. / Nm):
Type:
1.6L turbo-diesel
Bore & stroke
(in / mm):
Block material:
Cast aluminum
Cast aluminum
Valvetrain:
Fuel delivery
Horsepower
(hp / kW @ rpm):
Torque
(lb.-ft. / Nm):
TRANSMISSION & AXLE
Type:
Final Drive Ratio:
