While I don't like the idea of having DOHC on an engine that seems to be doing just fine with OHV and 2 valve per cylinder (and hasn't even used 3 valve pushrod heads or DI on any engine, let alone AFM or VVT on the Vette), the document does seem to support the DOHC 6.2L V8 engine. See around pages 51 and 55:
http://www.futureoftheunion.com/docs/delphi/Ex1toproposedorder149pages.pdf
I also wonder, since we've heard absolutely NOTHING about the Ultra V8 in recent memory, if Cadillac just got lazy and decided to slap a set of DOHC heads on a Chevy smallblack (as in the original ZR-1) and call it a day. That engine would be well placed to go up against the Mercedes AMG "63" DOHC V8 (which actually has 6.2L as well). The only problem then, is with the tall DOHC heads on a big V8, while these engines would fit into the Escalade and pickups just fine, how well would they fit under the hood of the cars?
I really hope GM knows what they are doing with this move. The simplicity of the OHV motors has made them affordable, durable, torquey, fuel efficient, compact, light, and led to a loyal following--something you can't quite say about Ford's modular V8s.
