While a 137-hp turbo-diesel engine may not immediately conjure the promise of performance, it does provide enough motivation for just about any type of situation you’re likely to encounter while behind the wheel of a compact SUV. That includes chirping the tires, albeit in its own special way: Putting your foot to the floor results in a lackadaisical step-off followed by a swell of torque that comes on and breaks the tires free while rolling at about 5 mph. All 240 lb-ft of torque are on board at a low 2000 rpm, and peak horsepower arrives at 3750 rpm; combined, they make the zone between 1800 and 4400 rpm fertile ground for harvesting acceleration.
The six-speed automatic transmission is astutely tuned for the 1.6’s unique properties and makes no qualms about downshifting at the slightest provocation of the throttle to make the most of it. Whereas the Cruze diesel gets a nine-speed automatic, GM claims that transmission offered no fuel-economy benefits in the Equinox so it gets the carryover six-speed gearbox. Additionally, the diesel utilizes a taller 2.89:1 final-drive ratio whereas the nine-speed cars use either a 3.17, 3.50, or 3.87 final drive, depending on engine, transmission, and driveline combination.
