2013 Equinox Water sloshing noise and wet carpets.
9.6K views 4 replies 5 participants last post by  Neanderthal
#1 ·
I recently acquired a 2012 equinox and the carpets are wet and there was a sloshing noise when making a left turn only. The water does not look like anti-freeze or doesn't smell like antifreeze.
Also, the AC fan motor slows down when the sloshing noise occurs on the left turn. No noise on right turns and the fan motor does not change in speed.
VIN#2GNALDEKXC6198635
Any suggestions are appreciated thank you.
#2 ·
#1 Is the radiator full of coolant? Could have water in it, so no coolant smell.
#2 Could be the a/c drain (under the vehicle is clogged). If so the drain will drain inside the vehicle. Probably have to be put on a lift to unclog.
#3 ·
Hello Chipsahoy,
I'm sorry to read about this issue you are experiencing with your vehicle. With the information that you provided I was able to research the vehicle history. I'd like to assist you in finding a resolution for this concern. If you would PM me your name, current mileage, address, phone and the name of the dealership you are working with, I'll being the process of researching some options available to you.
Marlea Wilson
GM Customer Service
#5 ·
Sounds like a leak. Call a Dutch boy.
