Started about 3 months ago. 120k miles. Been using GTX 5-30. After recent oil change it started lasting over 3-4 minutes on a cold start. Truck is garaged in heated area. It occurs after sitting for more than 4 hrs.', or in my case all night. I know this is old hat to most of you but it could become costly.
Looked up some remedies, short term to be sure and one of them was to drop a qt of oil and replace with ATF. Run at 1500 rpm for about 15 minutes and then drop oil & filter and replace with fresh. What are your thoughts on this procedure? Also I've read that some change out 5 qts of oil + add a quart of Mystery oil. Does any of this have any merit? Truck does not use oil. Performance so far is great. I do not put a load on it while it 'ticks'. I warm it to op temp and when engine is quiet I drive off. this can take up to 5 to ten minutes ...
Any info would be helpful
thx c/k
thx c/k
