2005 equinox vibration
1 reading
19K views 5 replies 5 participants last post by  lookingforhelp
#1 ·
I have an 05 Equinox AWD automatic. It has a vibration throughout the car when I am driving between 35 and 50mph. If I let off the gas, or apply the brakes, the vibration stops. It only vibrates when I'm on the gas between 35 and 50. A friend said it might be the steering column. Does that sound reasonable? If so, does the whole steering column have to be replaced? (It also makes clanking sound over bumps, but I think that is because I need to replace the front brake caliper bushings)
#2 ·
The fact that it stops when you apply the brakes makes me think torque converter--you're causing it to unlock--especially also because that speed range is generally when it is locking up. I'm not sure how a vibration in that speed range and that goes away when you let off or hit the brakes has anything at all to do with the electric steering, but that's just me.
Hopefully some of the techs chime in with more detailed ideas or info from similar issues they've dealt with.
#4 ·
There is a support mount with a bearing on the rear driveshaft.Crawl under the truck and check it out.The rubber mount breaks and will cause a terrible vibration.The mount is located in the middle of the truck.
