1 - 5 of 5 Posts
So I'm thinking about changing the wheels and tires on the '00 Monte Carlo SS, it's black by the way. I need to be a bit careful though because the car will continue to be a daily driver all year round but obviously in the winter the summer tires will come off and the snowies will go on. That said, I need your help!
- black car, and I like black wheels with a chrome lip. I saw these Boss wheels and really like them but they're not available for the Monte from what I can tell.
- I'm thinking I might need to lower the car a bit because I don't want it to have nice wheels but still sit too high, a friend suggested coil overs that I can adjust the car in the summer and winter as needed. What are your thoughts? Pros vs cons?
- looking for a 17" rim most likely because I want to keep a decent amount of sidewall in a tire, I think stock on these Montes are 225/60R16s, I'd like to stay with at least a 40mm sidewall.
Can you think of any wheels that might interest me? And what are your thoughts on coil overs or an alternative. Thanks!
Unless you're going to get big, cross-drilled rotors, you should stay away from wheels with such huge openings (IMO).
But I honestly can't think of any aftermarket wheels that would look good on a sixth-gen SS. Hmm..
there's a number of tiresize calculators on the web but this one came up first when I googled
Don't think you'll have any problem with "like to stay with at least a 40mm sidewall"... (that's less than 2" eek)
keeping under 1% diff in size/speedo-error:
245/50r17
265/45r17
didn't check availability but www.tirerack.com would at least give an idea
& you can use their tools and ratings as a starting point
You definitely need spinners. Nothing says class like spinners!
Seriously, I know very few people that buy big rims and tires without having problems. They look good but can be a real pain in the butt. Flats are never fun! IMO, I'd save my money and throw the cash into a CD.
I think that maybe you should look into getting a set of current MC SS's wheels, 18's!
I think that a classic 5 spoke desing would go well for your car.
As for lowering the car, going with a good set of lowering springs as well as maybe adjustable rate struts front and rear could go a long way to increase the handling of the car.
Tires you will be looking for would be a 225/55-17 or 235/55-17. Or you can go crazy like the GP GXP and put on a set of 255's...ohhh yeah.
1 - 5 of 5 Posts
