1 - 8 of 8 Posts
can anyone post the following Technical Service Bulletins (TSB)?
Make : CADILLACModel : ESCALADEYear : 2007Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 060864027Date of Bulletin: MAY 01, 2007NHTSA Item Number: 10021819 Component: VISIBILITY:REARVIEW MIRRORS/DEVICES:EXTERIORSummary:
LEFT OR RIGHT OUTSIDE REARVIEW MIRROR GLASS SHAKE/FLUTTER. *KB
Make : CADILLACModel : ESCALADEYear : 2007Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 070848001Date of Bulletin: FEB 01, 2007NHTSA Item Number: 10021335 Component: VISIBILITY:WINDSHIELDSummary:
FRONT WINDSHIELD GLASS OPTICAL DISTORTION OR STRESS CRACKS. *KB
Make : CADILLACModel : ESCALADEYear : 2007Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 060730019Date of Bulletin: JAN 01, 2007NHTSA Item Number: 10021119 Component: POWER TRAIN:AUTOMATIC TRANSMISSIONSummary:
6L80 TRANSMISSION HESITATION, SAG OR LACK OF ENGINE RESPONSE, BUSY TRANSMISSION SHIFTING WITH CRUISE CONTROL ENGAGED, ENGINE STALLS ON INITIAL COLD STARTUP (REPROGRAM TCM). *KB
Make : CADILLACModel : ESCALADEYear : 2007Manufacturer : GENERAL MOTORS CORP. Service Bulletin Num : 060730010Date of Bulletin: JAN 01, 2007NHTSA Item Number: 10020765 Component: POWER TRAIN:AUTOMATIC TRANSMISSIONSummary:
6L80 AUTOMATIC TRANSMISSION 4-5 UPSHIF SLIP/FLARE RESULTING IN A HARSH SHIFT OR CLUNK, MIL ILLUMINATED, DTC P0756 SET. REPROGRAM TRANSMISSION CONTROL MODULE (TCM). *KB
Subject:Left or Right Outside Rearview Mirror Glass Shake/Flutter (Relearn Power Mirrors) #06-08-64-027C - (06/12/2007)
Models:2007 Cadillac Escalade, Escalade ESV, Escalade EXT
2007 Chevrolet Avalanche, Silverado (New Style), Suburban, Tahoe
2007 GMC Denali, Sierra (New Style), Yukon, Yukon XL
with Power Folding Mirrors (RPO DL3)
This bulletin is being revised to include the Silverado/Sierra (New Style) models. Please discard Corporate Bulletin Number 06-08-64-027B (Section 08 - Body and Accessories).
Condition
Some customers may comment that the left or right outside rearview mirror glass shakes or flutters at normal driving speeds.
Cause
• The mirror may have been accidentally pushed in manually or obstructed while folding.
• The mirror actuator screws may be loose, allowing the mirror to move.
• The metal spring (driver's side mirror) may not have enough tension to hold the mirror from moving.​
Correction
Follow the procedure below to correct this condition.
  1. <LI type=1>The power folding mirrors should be cycled three times to relearn position. Then perform a road test and check the mirror glass for stability. If stability is not fixed, proceed to Step 2. <LI type=1>Remove the mirror glass. Refer to Mirror Face Replacement in SI. <LI type=1>Check the torque on the four retaining screws on the actuator. Tighten
    Tighten the screws to 1.13-1.6 N·m (10-14 lb in).
    <LI type=1>Bend the metal spring (driver's side mirror) up to increase tension engagement to the mirror housing 13 mm (1/2 in).
  2. Install the glass assembly by pressing firmly, taking care not to allow the spring finger to unseat from its intended track in the mirror housing. Road test the vehicle. If stability is not improved, replace the mirror assembly. Refer to Power Mirror Replacement in SI.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
B4150
Glass, Outside Rear View Mirror-Right - Replace
Use Published Labor Operation Time
B4151
Glass, Outside Rear View Mirror-Left - Replace
Add:
For Checking Torque and Repositioning Spring and Road Test
0.3 hr
*B9798
Relearn Power Folding Mirrors and Road Test
B4156
Mirror, Outside Rear View-Left - Replace
B4155
Mirror, Outside Rear View-Right - Replace
A1240
Mirror, Outside Rear View - Color/Clear Coat - Right
A1241
Mirror, Outside Rear View - Color/Clear Coat - Left
*This labor operation number is for bulletin use only. This number will not be published in the Labor Time Guide.
Subject:EI07036 - End of Request for Front Windshield Glass Optical Distortion or Stress Cracks (Enginering Information) #07-08-48-001A - (03/28/2007)
2007 Chevrolet Avalanche, Silverado (New Body Style), Suburban, Tahoe
2007 GMC Sierra (New Body Style), Yukon, Yukon XL
Built On or After September 1, 2006
This bulletin is being issued to cancel Corporate Bulletin Number 07-08-48-001 and end the request for Engineering Information (EI07036). Please discard Corporate Bulletin Number 07-08-48-001 (Section 08 -- Body & accessories).
Resolution
Through the information gained from this service bulletin, a series of incremental engineering changes are being reviewed and the appropriate response/action will be taken to address this concern. Thank You to all those who offered your timely and valuable assistance in support of this effort.
Instructions
If the customer brings a vehicle in with one of these concerns, no special action is required. Follow normal review/replacement procedures.
Subject:Front Windshield Cracked / Engineering Investigation - keywords body front glass #PIT3952A - (01/17/2007)
Models:2007 Cadillac Escalade, ESV, EXT
2007 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007 GMC Sierra, Yukon, Yukon Denali, Yukon XL, Yukon Denali XL
This PI was updated to revise recommendations. Please discard PIT3952.
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
A vehicle may be brought in for a customer concern of stress-cracked windshield or visible distortion. There is an engineering investigation for front windshields with a stress crack or visible distortion (items being viewed through glass appear distorted or blurry when looking through some portion of the glass). This engineering investigation is for North America.
Recommendation/Instructions:
  1. <LI type=1>Check the vehicle build date. Respond to this only if the vehicle was built on/after 09/01/06. Record the vehicle build date. <LI type=1>If the glass is cracked, verify that the crack occurred due to stress (not caused by impact). Disregard this bulletin if the crack was not caused by stress. <LI type=1>Record the information stamped on the bottom right corner of the glass (write down or photograph). You will see some number of dots before or after a "6" or "7". In many cases, you'll also see a number of dots before or after a "D" and an "S". This is the production date code for the glass. The information always tells us month and year of build of the glass, and sometimes tells us Day and Shift. Number, location, and orientation of dots, relative to the number or letter, is important. <LI type=1>Gather details about the crack or distortion problem:
    For STRESS CRACKS, record: The exact location of the crack's origin. Did the crack originate at one of the edges of the windshield (A pillar, cowl, roof) or away from all edges? How far, in and up, is the crack's origin (from some reference point)? Which direction did the crack run (straight up/out or at a diagonal)? Did the customer provide additional information regarding the crack (e.g. noticed/did something prior to crack forming)?
    For DISTORTION, record: Nature, location/area, and size of the distortion. Where is the viewer sitting and looking when he/she sees a distorted view? What is distorted about the view (e.g. all is blurry, horizontal lines look wavy, vertical lines look wavy)?​
    <LI type=1>Please do not replace the glass.
  2. Contact xxxxxxxxxxxxx, GM Warranty Engineer, at (248) xxxxxxxx and provide: Vehicle build date, VIN#, RO#, date code information from the stamp on the glass, issue detail (see #3 above, details about the crack or distortion problem).
Engineering may visit dealerships which are near Detroit, MI (within 2 hours) or close to one of the Full Size Truck assembly plants. GM or the windshield supplier may make arrangements to have the glass shipped to a chosen facility. In either case, a decision will be made based upon the information provided. Feedback/Disposition will be provided to you within 48 hours of phone call.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Subject:6L80 Transmission Hesitation, Sag or Lack of Engine Response, Busy Transmission Shifting with Cruise Control Engaged, Engine Stalls on Initial Cold Startup (Reprogram TCM)) #06-07-30-019A - (01/04/2007)
2007 GMC Yukon Denali, Yukon Denali XL
with 6L80 Automatic Transmission (RPO MYC)
This bulletin is being revised to update the correction information. Please discard Corporate Bulletin Number 06-07-30-019 (Section 07 -- Transmission/Transaxle).
Built Prior to the Following VIN Breakpoints:
Plant Location
VIN Breakpoint/Date
Arlington
7R234718 (7/24/06)
Janesville
7J213410 (7/25/06)
Silao
7G157123 (8/01/06)
Condition
Some customers may comment on the following conditions:
• A hesitation, sag or lack of engine response while accelerating. This typically occurs after backing off the throttle then shortly stepping back in to a heavy or wide open throttle position. This condition may occur at any speed, but is most likely to occur after accelerating to 48 to 80 km/h (30 to 50 mph), backing off the throttle then stepping back in. A 1.5 to 2.5 second delay may occur before the vehicle resumes acceleration.
• Frequent transmission shift cycling occurring on slight to moderate grades when in cruise control at vehicle speeds from 64 to 121 km/h (40 to 75 mph). The customer comment may include "too much vehicle speed variation from the desired cruise control speed setting" when the shift cycling is evident.
• On the initial cold startup when ambient temperatures are below -22° C (-8° F) and an engine block heater is not used, the engine starts and may immediately stall. The engine will typically restart immediately and operate normally.​
Correction
A revised transmission calibration has been developed to address these issues. Reprogram the transmission control module (TCM) with an updated software calibration. This new service calibration will be released with TIS satellite data update version 8.0 or later, available August 14, 2006. As always, make sure your Tech 2® is updated with the latest software version.
After reprogramming the TCM, Service Fast Learn Adapts must be performed using the Tech 2®. Check and clear all DTCs that may have set as a result of the programming process .
Labor Operation
Description
Labor Time
K9509*
Transmission Control Module - Transmission Reprogramming with SPS
0.4 hr
Add:
Diagnosis Time and Drive Procedure
0.0-0.3 hr
*This labor operation number is for bulletin use only. This number will not be printed in the Labor Time Guide.
Subject:6L80 Automatic Transmission 4-5 Upshift Slip/Flare Resulting in a Harsh Shift or Clunk, MIL Illuminated, DTC P0756 Set (Reprogram Transmission Control Module (TCM)) #06-07-30-010C - (01/04/2007)
This bulletin is being revised to update the correction information. Please discard Corporate Bulletin Number 06-07-30-010B (Section 07 -- Transmission/Transaxle).
Plant
VIN Breakpoint
Arlington
7R141629
Janesville
7J125624
Condition
• A 4-5 upshift slip/flare that results in a harsh shift or clunk at the end of the shift.
• An illuminated MIL where a DTC P0756 is found as a history code in the TCM.​
Correction
A revised transmission calibration has been developed to address both of these issues. Reprogram the TCM with an updated software calibration. This new service calibration was released with TIS satellite data update version 3.5 or later, available March 20, 2006 (March 22 in Canada). As always, make sure your Tech 2® is updated with the latest software version.
After reprogramming the TCM, Service Fast Learn Adapts must be performed using the Tech 2®. Check and clear all DTCs that may have set as a result of the programming process.
Labor Operation
Description
Labor Time
K9509*
0.4 hr
Add:
Diagnosis Time
0.0-0.3 hr
Discussion Starter · #7 ·
this is great thanks.... I went to repost it and thought I had deleted the earlier one somehow. Thanks for all your help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:)
I have a 2007 Escalade and recently brought it in for service. I feel and hear a bang when accelerating from a stop, feels like loose front end or motor mount. Dealership said there was a bulletin issued by GM saying this was normal to hear when accelerating or steering side to side could cause it. Was there any such notice about this?
1 - 8 of 8 Posts
