Basically there are some inherent harmonic disturbances, and weaknesses that the previous GEN IV engine had that in many ways limited the AFM activation envelope in the interest of NVH among other things.
Chrysler's MDS system allows more NVH to enter the interior of the vehicle but it's activation envelope is far greater than GM's AFM system at this current time because of improvements made in these areas in many ways.
If you truly look into the relatively thirsty, and dirty combustion chamber design of the HEMI it also shows that it's greater MDS activation envelope has a notable affect on fuel economy. < Hmmmmm yeah 'ok'...... sorta'..... but...... >
I believe that America123 is alluding to the fact that they for all intents and purposes have barely scratched the service of what active fuel management is capable of, and in many ways they simplified it because of inherent GEN IV issues.
. In fact my Escalade does not even have AFM, and they only recently started to offer AFM on the L92 utilized in the Escalade. < Yes indeed, there is also the aspect of what displacements - and installations got AFM.... when >
One would have to really peruse the LT1 data as America 123 and I have to read between the lines, and see exactly what we are referring to.
In many ways the changes that were made had other reasons aside from those relating to power.
This Gen V V8 in it's initial format will offer only a slight increase in < HP with a large torque increase - which also 'needed' some of the seemingly more generic improvements to be workable > power but significant increases in fuel economy in my opinion.
Basically the Gen V V8 had very necessary changes made to it that were needed circa Gen III V8 many of which were not related directly to power, and basically when they say new combustion system we are truly looking at a combustion system that is the only one of it's kind.
In essence they have been robbing Peter to pay Paul, and not only do Peter and Paul need payment but the whole manner in which they are paid needs to be changed.
Yep, pretty much most of it and pretty well said. :yup::yup::yup:
And I know you will understand what I say next and not take it the wrong way.....
Now you very likely have the basis for ..... a
fully and truly world class xyz - good enough for Cadillac installation in the best sense of those terms - btw.
People are worried about the new 5.3L being 'only' 350hp, but DI is really only supposed to boost power about 1/8th. So 315hp x .125 = 40hp. This puts it right at 355.
America123, I'm guessing the 'stage two' will be sparkless ignition? I would think that would work better with big inch, low rpm engines that aren't running up and down the rev range all the time. That would be something. You'd think it would be perfect for series hybrids where the engine runs at one rpm or a very narrow rpm range.
But in the near term, just a 24mpg, 350hp Silvy seems like a big deal. I think despite all the kvetching we did about Eco-Boast that Silvy will be retaining that 'least expensive to own' laurel with better across the board economy.
I think the trick from the bean counter viewpoint will be that they will be selling less expensive-to-make Silvys that match Ford's DOHC V6 against a DI OHV V6, and an OHV V8 against a turbo DOHC V6.
WRT to the HEMI, I get 20mpg hwy evert time in mine - but with the AFM kicking in and holding for long periods even at 65mph. Chevy 5.3 gets that kind of mileage with the AFM only kicking in downhill. With a more 'aggressive' AFM that can go down to 2 cyls < I think ? you mean lose two and down to six ? >and/or have 'rolling' deactivation that might decrease the vibration factor - and factor in the 500lb weight loss - I think we may be seeing the "V8 power V6 economy" ads. 18mpg city would match the '13 V6 8spd Dodge.
Lot to this post.
Well worth discussion....
I'm short, so just a few things for now - but you are definitely on some of the right tracks available - which under the right circumstances, still does not preclude smaller displacements in certain smaller and lighter applications........ if you will.
Yes, the later type is all about providing - if you allow some latitude in the terms - all about getting to an HCCI....... or........ a related type
combustion mode or better said, -
getting in and out of something like that - it's the transitions and transients that are the
really hard part for all that.
So yes, perhaps more ....... and definitely more and different
modes of combustion and therefore - yet again a different combustion system.
'Imo' this LT1 and it's likely brethren address all the inherent deficiencies or limitations in all the previous sbs - that not only are 'desirable' for other reasons both generic and specific - including creation of the LT1 pkg itself but are also
required for that second combustion system.
Just look at how they handle the basic wet sump oiling system and related air /oil separation - pcv.
On the one hand, gee, a gen 3 or 4 etc could have really benefited from that in practical real world terms.... - big useful margin for real world ****ty oil and fueling effects
as they specifically express in these - and including when all ****ed up by that and then also in AFM mode.
However, is all of that
really required for
all of the LT1s - or more to the point - for a LT1 truck derivative ?
Maybe.... maybe not...... or maybe........ not so much.
What
is absolutely clear - is you do need it for HCCI and related.
And lets be clear
you need it to be real strong and real good -
so why not run it out there 'early' and make sure of it... besides, it can only also 'be good' for the LT1 etc.
So again, multiple ( possible ) and possibly shifting in sense purposes or reasons for a feature - with regard to past, soon to be present, and ..... future.
The LT1 and it's compatriots are apparently ...or perhaps...... the bridge...... somewhat like aspects of some of the Gen 2s were. That's a very imperfect analogy but has an element that's useful .
Geermezy1 does point out something real relevant - much of this other improvement is 'catch up'. Beyond belief - if you want to get real hard nosed about it.
Anyway.....
You can kinda' put it all together from one point of view ie 'catch up' that now has sufficient value - according to 'Mgt'.
You know, some of the same bozos who put it off for a really long time..... to chase the Prius - a task not worth doing.
I wouldn't - but some would
and by golly, they most certainly did.
Oh well......
Five to ten years late is still better than -
The important thing is - now it's done.:yup:
