"School of Hard Knocks" - Story on GM's HCCI
http://www.caranddriver.com
After more than a century leading separate lives, Rudolph Diesel and Nikolaus Otto are finally getting a place together. General Motors’ experimental 2.2-liter homogenous charge compression ignition (HCCI) engine can shift from spark ignition to diesel mode faster than you can say “außerordentlich!”
The goal: stretch fuel economy from an existing engine design by up to 15 percent by adding just a few bits of hardware and some software code.
Able to burn either gasoline, ethanol, or E85, the HCCI design utilizes direct injection and variable valve-timing hardware to switch from spark ignition during acceleration and high speed to compression ignition during idle and light-throttle cruising.
Continue Reading...
Continue Reading...
