1 - 13 of 13 Posts
Option Code Description
A45 Memory Package
AL2 Seat adjuster, power
AP3 Keyless Access, includes keyless ignition which is engaged with push button start
AP9 Convenience Package, includes universal transmitter garage door opener
AQ9 Seats, front bucket
AY0 Air bags, frontal dual stage and side thorax for driver and front passenger
B19 Wood Trim Package
B20 Wood Trim Package, includes real eucalyptus wood on steering wheel
CE1 Wipers, Rainsense
CE4 Headlamp washer system
CF5 Sunroof, power
DD7 Mirror, inside rearview, electrochromic
DD8 Mirror, inside rearview, electrochromic
DR2 Mirrors, outside rearview
DT4 Smoker's Package
FE1 Suspension, 4-wheel independent
FE3 Suspension, 4-wheel independent with Magnetic Ride Control
FE9 Emissions, Federal requirements
JE5 Brakes, 17"
JL4 StabiliTrak
JL9 Brakes, 16"
K05 Engine block heater
K14 Air filtration system, outside recirculating air filter
K59 Cruise control, adaptive
KA1 Seats, heated
KA6 Seats, heated
KB6 Seats, heated/ventilated
LH2 Engine, 4.6L Northstar V8 VVT
LY7 Engine, 3.6L V6 VVT
M22 Transmission, 5-speed automatic
M82 Transmission, 5-speed automatic
MV3 Transmission, 5-speed automatic
N31 Steering wheel, heated
N87 Wheels, 4 - 18" x 8" (45.6 cm x 20.3 cm) cast aluminum polished
N88 Wheels, 4 17" x 7.5" (43.2 cm x 19.1 cm) cast aluminum painted
N93 Wheels, 4 - 17" x 7.5" (43.2 cm x 19.1 cm) aluminum polished
NC1 Emissions, California LEV
NE1 Emissions, Geographic Restriction for up to 14,000 lbs. GVW
NG1 Emissions, Geographic Restriction for up to 6000 lbs. GVW
NP5 Steering wheel, leather-wrapped rim
NR7 Steering wheel, leather-wrapped rim
NT7 Emissions, Federal
NT9 Emissions, Federal
NU1 Emissions, California
NV7 Premium Steering Gear, ZF
Q11 Tires, P235/50R17 front and P255/45R17 rear
Q12 Tires, P235/50R18 front and P255/45R18 rear
Q13 Wheels, 2 - 17" x 7.5" (43.2 cm x 19.1 cm) front, 2 - 17" x 8" (43.2 cm x 20.3 cm) rear
Q14 Wheels, 2 - 17" x 7.5" (43.2 cm x 19.1 cm) front, 2 - 17" x 8" (43.2 cm x 20.3 cm) rear
QKP Tires, P235/50R17
T43 Spoiler, decklid
TQ5 Headlamps, Intellibeam
TT6 Headlamps, Xenon, high-intensity discharge
U2K Sound system feature, XM Satellite Radio
U30 Instrumentation, analog
UA6 Theft-deterrent system, PASS-Key III
UD7 Rear Parking Assist, Ultrasonic
UE1 OnStar
UG1 Universal transmitter, HomeLink
UJ6 Tire pressure monitor system, air pressure sensors in each tire
UV6 Head-Up Display
V03 Performance Cooling Package, includes P/S cooler
V08 Cooling system
YF5 Emissions, California state requirements
YQ1 Sound System, ETR AM/FM Bose 4.0 with CD player
YQ2 Sound System, ETR AM/FM Bose 4.0 with in-dash 6 disc CD changer
YQ3 Sound System, ETR AM/FM Studio Surround Sound Bose 5.1 with in-dash 6 disc DVD changer
YQ4 Sound System, ETR AM/FM Studio Surround Sound Bose 5.1 with in-dash 6 disc DVD changer
Engine, 3.6L V6 VVT (260 HP [193.9 kW] @ 6500 rpm, 252 lb.-ft. [340.2 N-m] @ 2800 rpm)
1 - Requires (M82) Transmission, auto, 5-speed, HMD, 5L40-E
Engine, 4.6L Northstar V8 VVT, SFI variable valve timing, Northstar (320 HP [238.6 kW] @ 6400 rpm, 315 lb.-ft. [425.3 N-m] @ 4400 rpm)
1 - Requires (M22) Transmission, auto 5-speed, HMD, 5L50-E for RWD or (MV3) Transmission, auto, 5-speed, HMD, 5L50-E PTU for AWD
Not to doubt or anything, but all these RPO codes are available on current Cadillacs from the CTS to XLR, by the way wheres the night vision? The AWD does sound very cool, I had heard back in 98 that Cadillac was working on a 400 HP rwd or awd Seville, I guess were halfway there, all we need to do is wait for the V series, there is another importaint option code missing though, the one for the 6 speed manual!
:lol:
The AWD option on the STS is old news.
Anyone figure out what "Intellibeam" is? It's for the headlights.
Is that like the existing Twilight Sentinel or more like BMW's headlights that adjust angles as you turn??
Maybe it's some sort of adaptive lighting, where it can automatically vary the intensity? Or maybe the "turning" headlamps that you mention, I would not doubt the later, since there are a couple of other luxury cars offering that now.
There is a company that makes something called an Intellibeam, and they are power lights, pretty much like Quad Xe lights...heres the link... http://www.getintellisense.com/pdf/DbeamsIN.pdf I am not sure if it has anything to do with it, but it may be a good indicator. The STS is lookin pretty good, but a spolier option ughhh, well at least its just an Option!!
Originally posted by TaHoE+Nov 24 2003, 07:03 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (TaHoE @ Nov 24 2003, 07:03 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-MCGARRETT@Nov 24 2003, 06:39 PM
There is a company that makes something called an Intellibeam, and they are power lights, pretty much like Quad Xe lights...heres the link... http://www.getintellisense.com/pdf/DbeamsIN.pdf I am not sure if it has anything to do with it, but it may be a good indicator. The STS is lookin pretty good, but a spolier option ughhh, well at least its just an Option!! [/b][/quote]
Some cars look much better with a spoiler.
CTS, Saab 9-5, Audi A6 .... just to name a few. It just spices up the rear a bit. I'm glad it's an option.
Ooh... that spoiler I saw on the CTS ... WOW.... really well done.
1 - 13 of 13 Posts
