Review: 2017 Chevy Cruze Hatchback (Premier, 1.4T/6A)
4 reading
551 views 12 replies 10 participants last post by  kirk.collicutt
#1 · (Edited)
The last of my long-winded personal car reviews!
This is my wife's car, she bought it new a month after I bought my SS sedan in 2017. It's her first brand new car and she loves it to death. Her previous ride was a 2-door 2008 Chevy Cobalt Sport (2.4L/4A). The difference in quality is staggering, but to its credit, the Cobalt was mostly trouble free for 100k miles and was traded in still running fine.
My wife wanted something practical and efficient, and she prefers a smaller footprint. I nudged her toward the hatchback body style because owning two sedans between us would have been needlessly limiting. I also think the Cruze hatchback looks better.
After some option hunting, we found her a Premier hatchback in Graphite metallic (dark teal, almost gray) with the light color leather interior she wanted after burning her legs on the Cobalt's black fake leather seats for 6+ years.
Today, the Cruze has 105,000 miles and the ownership experience has been so positive that my wife dreads the thought of replacing it as the odometer creeps higher. The car still feels tight and has few squeaks and rattles. I vacuumed and wiped down the interior and you'd swear this car had less than half the mileage.
Let's get into how it drives:
The second generation 1.4T ecotec makes 153 horsepower and 177 lb-ft of torque and the hatchback weighs just under 3,000 lbs. Not a bad combination. It does have start/stop which I would erase from the industry if possible, but GM makes a pretty tolerable system.
After a bit of lag, the Cruze takes off with a hint of the charm the old 3100 V6 had in cars like the Grand Am GT. A Car & Driver test of a hatchback premier with nearly identical options ran 7.7 seconds to 60 mph, and a 16 flat @ 87 mph. Not fast, but it gets out of its own way better than many economy cars and the torque is real-world useful.
The 6-speed automatic is reasonably well sorted, but still likes to bog the engine for fuel economy at times which can be annoying. It downshifts noticeably better than earlier versions.
The handling is surprisingly good. While not fully independent, the Premier has an upgraded rear with a watts z-link suspension, and the 225 section tires on the standard 17s offer a significant contact patch for a light-weight compact. The EPS is numb, but not over-boosted and doesn't kill the experience.
The ride is taut and controlled while being comfortable. You won't confuse this car for a soul-sucking, floaty crossover, which my wife and I both like.
The brakes (4-wheel disk, ABS) are adequate. Pedal feel is a weak spot. It's placed a little too high vs the accelerator which makes for clumsy transitions when you're not used to it and doesn't bite like I want.
Fuel economy has been a highlight of ownership. We used this car for 500 mile road trips and 40 mpg highway is almost a foregone conclusion. Once we hand-calculated 42 mpg with both of us and our luggage. This is especially welcome considering the decent power it has. It rarely dips below 30 mpg for any reason.
Inside the car, the cabin is the quietest with the most comfortable seats of any compact or economy car I've driven or ridden in. The interior has great fit and finish, an attractive design, and intuitive controls/features. The steering wheel has those rubber pads for buttons which I hate as far as looks and tactile feel, but somehow they look brand new after a wipe down so they're not all bad.
Cabin space feels like a midsize with room for 4 full size adults comfortably, plus a 5th penalty seat in a pinch. It currently has two easily anchored child seats in back. Cargo room with the hatch opening and split folding seats swallows everything we ever needed it to.
The premium stereo is the Bose centerpoint nonsense GM put in everything. Factory settings are terrible, but the system sounds decent when adjusted properly.
For my wife, who used to commute 300 miles per week on a busy highway, the Cruze was a revelation, and probably why she loves it so much. It's not sporty in its manners, but it makes usable power and handles well. It's like it was engineered to make driving easy, just not necessarily "fun."
Reliability:
+..Wife never stranded, no major failures.
+..Original battery lasted 7 years, no issues with any parts related to start/stop.
+..Original brakes are still on the car with some life left (I'll be changing them soon anyway).
-..TWO of the 17 inch alloy wheels have bent from pothole impacts, and we don't live in Detroit, one repaired and the other needed replacement.
-..The cabin filter is a 30 minute job because you have to tear the passenger area trim apart instead of just dropping the glove compartment.
#2 ·
GM has come a long way with the interior staying tight as the car ages. It's been a long time since I've had annoying squeeks and rattles in my GM's. And GM has been accused of using cheaper materials, but they hold up. If you don't manhandle the interior the finishes stay nice if you clean them.
I liked the hatch - great looking design.
#3 · (Edited)
I recently replaced the brakes for the first time at 62,000 miles on my 2018 Cruze LT diesel hatchback. The only thing I have done besides routine maintenance is replace a diesel exhaust particulate sensor. My Cruze uses very little oil and does not require adding oil between oil changes as compared to the Corolla that the Cruze replaced eventually needing oil added every other fill up. I have never had to do a four wheel alignment on the Cruze. The Corolla required front brake replacement approximately every 35,000 miles and needed alignments, tires, front wheel bearings, serpentine belts, and pretentioners on an unusually frequent basis. My battery lasted 7 years too and I maybe got 3 years from the Corolla batteries. Also, the Cruze's headlight and other light bulbs have never been replaced and the Corolla bulbs seemed to need replacement on an usually frequent basis.
#9 ·
Glad to see so many Cruze enthusiasts here. It's without a doubt one of GM's most underrated models and probably the best compact to come out of an American automaker.
I once had a 1st gen Cruze 2LT for a week as a rental and had a lot of similar feelings about it: spacious, very well-built, quiet, good looking inside and out. My one complaint was that the old 1.4T and lazy automatic tuning didn't match well with the car's weight, which was over 3200 lbs. I probably would have liked the Eco trim just fine with the lower weight and the better gearing of the manual. Or the little Chevy Sonic for that matter, another great Chevy compact lost to history.
I TOTALLY forgot about the diesel model! What a crazy little unicorn that was. The fuel economy ratings were insane! The Corolla generations that competed with either Cruze were such lame cars. My best friend had a 2009 and that thing was the definition of an economy compact. It had a bleak interior and the seats used to kill my back on road trips longer than an hour. Wasn't bullet proof like the 90s model, either.
As far as oil, our Cruze has never consumed any between changes either, even long intervals. I was kinda surprised by that, being a high-strung GDI turbo.
#4 ·
My sister owns a 2018 Cruze LT sedan. It’s around 185,000 km now and she bought it new. Can you believe it’s NEVER had a check engine light? It’s been flawless from a reliability standpoint and still has no leaks or rattles. This summer has presented an A/C issue that will need addressing though. Still, no rust, a few battle scars but it’s been a great car. She’s in the process of buying a new family suv right now, and when she picks one I’ll be buying the Cruze.
#5 ·
We have a 2011 Cruze sedan LTZ RS. It has fake leather , a sunroof and the better suspension with watts link etc. This summer I started to drive the Cruze daily to work and am amazed how good the car still is. There is no rust , the paint looks great and its original, The car is black, with black fake leather interior. The seats are not torn or cracked We have not made any repairs to the car in 14 years , just maintenance . Oil changes , pads and rotors this past summer . Changed the plugs, Fuel injection cleaner, Transmission fluid, wiper blades and 1 set of new Michelin tires a few years back. We change oil spring and fall and use premium fuel. We love the car and will never part with it , as we have several other vehicles including a 2020 top tier Equinox midnight with 2.0L. AWD, 9 speed , leather , sun roof etc , a 2024 Colarado Z71 crew cab . Sorry i do not have pics that i can upload, but many people who see the car thinks its new. Recently I read an article from 2011 when they reviewed a car almost identical to our and the article said that the car was at the top of its class in 2011. I almost bought a 2019 premier hatchback RS , but could not get the options we wanted so kept the 2011. Its truly a shame that GM did not commit to keeping the Cruze and updating it as other manufactures do , ie Honda , Toyota, etc.
#13 ·
The Verano was a great compact. My daughter had a 2015 until it was involved in a collision . Very well built, quiet and comfortable.
It had the right blend of ride and handling. The Verano shared much with the European Opel version and was a nice step up from the cruze
GM is trying to replace those cars with the Trax and Envista.
These are excellent too , but somewhat larger than the Cruze
