"Researchers at Ohio State University have invented a new material that can generate electricity from heat in hot machine environments at an unprecedented rate.
The new material is called thallium-doped lead telluride.
The development could have a direct application for converting car engine exhaust heat into electricity, according to a statement from the university.
Using thermoelectric materials for generating power is not new. It is the group's improvements on this type of alloy that are newsworthy.
The group, led by Joseph Heremans, Ohio Eminent Scholar in Nanotechnology at Ohio State University, developed a material that is effective between 450 and 950 degrees Fahrenheit, the temperature range for most car engines.
"The material does all the work. It produces electrical power just like conventional heat engines--steam, gas, or diesel engines--that are coupled to electrical generators, but it uses electrons as the working fluids instead of water or gases, and makes electricity directly," Heremans said in a statement to the press."
Article continues http://news.cnet.com/8301-17912_3-9999450-72.html?part=rss&subj=news&tag=2547-1_3-0-20
Wouldn't this be incredible in an engine or laptop? Turning excess heat into energy would not only increase mileage (hybrid) but also increase efficiency within the engine! Could you imagine a hybrid Corvette ZR1 with this thing?
