1 - 2 of 2 Posts
I have a 08 Silverado 4 x 4 z-71 and in the process of installing a Rough Country lift. The front differential was extremely difficult to remove and proving even harder to reinstall. Any suggestions. Thanks
all I can say is if you think an 08 is hard definitely dont try an older model especially before 99. 08,s are very easy to get out 2 axle shafts,6 bolts each 2 bolts on drivers side 2 nuts on pass side 1 electrical connector and 4 clips,1 ventline and remove.also if I was you Id scrap the lift,they cause nothing but problems
1 - 2 of 2 Posts
