1 - 5 of 5 Posts
I am confuzed about the oil type. on the oil stick head it says 10w30 but on a label of the filter box it says 5w30 only. which one should I use?
if i use 10w30 are there going to be any problems?
thanks
thanks
Either will be fine. Personally, I'd go with the 5W-30. If it tends to be burning oil or leaking, then I'd thicken it up on the next change.
OK, you asked for opinions.
What's your temp range for the next four months?
According to people who know far more than I do, 5W-30 and 10W-30 are both fine. As is 5W-20. Check with your Buick dealer.
You'll probably get as many opinions as people you ask.
Keeping up on O&F changes is important.
http://www.popularmechanics.com/automotive/new_cars/1266801.html?page=3
To quote from my 2002 Regal owner's manual, p. 6-15:
[Chart recommends use of 5W-30 for 60*F and lower temps. Recommends use of 10W-30 0* and above.]
"As in the chart shown perviously, SAE 5W-30 is best for your vehicle. However, you can use SAE 10W-30 if it's going to be 0*F (-18*C) or above. These numbers on an oil container show its viscosity, or thickness. Do not use other viscosity oils, such as SAE 20W-50.
"SAE 10W-30 is best for your vehicle. However, you can use SAE 5W-30 if it's going to be colder than 60*F (16*C) before your next oil change. When it's very cold, you should use SAE 5W-30. These numbers on an oil container show its viscosity, or thickness. Do not use other viscosity oils, such as SAE 20W-50."
Clear as mud yet? :think:
1 - 5 of 5 Posts
