Cadillac's recent decision to move its corporate emblem to the top of the grille was, apparently, a very controversial move. While older models carried the badge dead center, current models have allowed the symbol to creep nearer to the hood latch. We failed to notice any riots in the streets over the change, but Cadillac Society contends there are a contingent of customers who don't appreciate the new look.
It also has the answers for why General Motors thought the modification necessary.
It doesn't take a PhD in visual design to figure out why, though. Due to Cadillac moving away from vertical headlamps, a central emblem would look a little goofy - kind of like it does on present-day Acuras. While we'll admit that the new badge placement was initially unsettling, akin to the creeping mole featured on Prince John in Robin Hood: Men in Tights, it was likely the correct choice.
Speaking with several GM designers, Cadillac Society said the decision ultimately came down to how weird the new models would look with a centrally mounted emblem:
While not heinous, the lower placement does look a bit off, disrupting that visual flow Cadillac was looking for to achieve better brand cohesion. The CT6 also has a fairly modest grille in relation to other Cadillac models. With all that negative space, the manufacturer had to either shift the badge up a few inches or make it bigger. Its final decision was arguably the more tasteful option. We previously mentioned Acura's visual missteps, but Mercedes-Benz can also be faulted for going overboard with gigantic branding - especially now that its emblems can be illuminated (for those who don't believe in subtlety).
But beauty is always in the eye of the beholder. Are you one of those people who found the evolving emblem placement unsettling, or is the new way better?
a version of this article first appeared on TTAC
The emblem is also no longer surrounded by a wreath, like it was back when you were cruising around in your STS. It's wider these days, allowing for a more at-home look higher on the grille. To better illustrate this point, here's an image of the current Cadillac CT5 (left) with a mockup of how it might look with center-mounted branding (right).
