My problem is that I can't stand the argument that, because a brand doesn't do something, they can't. Sometimes that is the reality, but people pull that tired old yarn out more than is remotely justified, and this forum is no stranger to it. And I can't help but notice that while my argument that Ford not building a bigger Coyote is a choice bothers you, those arguing that it's due to some mysterious inability at Ford to add an inch to the deck height of an engine block don't. My point was simply that Ford doesn't build a bigger engine, or a pushrod engine, etc, etc, etc, for the same reason that GM doesn't do a myriad of things. That reason being that Ford doesn't see a compelling reason to spend the money necessary to achieve those things rather than spend that money elsewhere.
Perfect example? Following some of the logic laid out earlier in this thread GM must be avoiding the vast majority of the sub 40k dollar performance car market because they either stink at it, don't have the ability to even build those cars in the first place, or both. Or, perhaps we should say that Ford builds supercars like the upcoming GT because they can and GM doesn't because they can't. The reality? GM isn't in those markets because they choose not to be in those markets, nothing more and nothing less. Ford doesn't build a bigger Coyote because, year after year, they choose not to build a bigger Coyote; not because they have some corporate-wide mental block that prevents them from building a taller deck version of the same block.
There, feel better now?
Feel better about what. Ford loves to brag about the superiority of the F-Series compared to it's competitors. Whether it's payload, towing, having the most torque and horsepower. Their F-Series ad's are chock full of this kind of stuff.
Now I never see Mustang ads on the air in my market, but if I did, what would Ford be touting? Styling, nostalgia, price I suppose? The problem is that it almost every performance metric that you can objectively measure the Mustang gets beat up on by the Camaro. And that's because GM developed a better chassis and a better powertrain then Ford did.
I never stated that Ford can't do something, props to Ford for developing the 5.4 SVT Terminator Mustang, the 5.8 GT 500, and the 5.2 GT350R
But on the other side, you can't accept that when comparing GT vs Z28 (93-02) or GT vs SS (10-15) the Mustang has always been saddled with an objectively inferior powertrain.
Now if you take 2011 which is the first year the Coyote competed directly against the LS3..........using manually equipped cars to make the comparison even,
Coyote: 412hp at 6,500 rpm/390 torque at 4,250 rpm
LS3: 426hp at 5,900 rpm/420 torque at 4,600 rpm
And let's compare what is on sale now.
2015 Mustang 5.0: 435 hp at 6,500 rpms/400 torque at 4,250 rpm
2016 Camaro 6.2: 455 hp at 6,000 rpms/455 torque at 4,400 rpm
If you put the LT1 in the Mustang it would perform better. If you put the Coyote in the Camaro it would perform worse. Case closed.
