5 Ways Chevrolet Made 2016 Malibu Segment’s Lightest
Approximately 300-lb weight reduction enhances efficiency, driving dynamics
General Motors
2015-06-17
DETROIT – Engineers developing the 2016 Chevrolet Malibu put the new midsize sedan on a strength-training program, making it sweat out a pound here and a gram there, in a quest to make it more fuel efficient, stronger and safer.
The result is an all-new Malibu that is nearly 300 pounds (136 kg) lighter than the current model – an achievement that not only gives it the segment’s lightest base curb weight, but also contributes to an estimated 48 mpg in city driving for the hybrid model and 37 mpg highway for the 1.5L turbo base engine. A lighter curb weight will also improve ride and handling.
Here are five of the most noteworthy mass-saving achievements:
1. Leaner, stronger body structure
More than a third of the 2016 Malibu’s mass savings – approximately 120 pounds (54 kg) – comes from its all-new body structure, which features greater use of high-strength steels, enabling the use of thinner components in some areas, while delivering comparable or better crash performance.
Development of the Malibu’s structure is the result of extensive computational analysis, which employed sophisticated modeling programs to simulate dozens of design iterations that indicated the most strategic placement for high-strength steel elements such as the pillars and rockers – all while maintaining higher targets for strength, stiffness and crashworthiness.
2. Greater use of aluminum
Light and strong, the incorporation of more aluminum in the 2016 Malibu contributes significantly to its lower weight. Examples include an aluminum hood that is 6.6 pounds (3 kg) lighter than current model’s steel hood, and aluminum suspension knuckles and chassis components, as well as lighter mounts.
3. Streamlined instrument panel assembly and lighter power accessories
New power window regulators collectively save 4.2 pounds (1.9 kg) – a 34-percent reduction over the current model, while another 2.2 pounds (1 kg) was saved by reducing the complexity of components within the instrument panel.
4. Lighter leather seats and other soft materials
The Malibu’s available leather seats are collectively 40.6 pounds (18.4 kg) lighter than the current model.
5. A lighter engine
The 2016 Malibu’s all-new, standard 1.5L turbo engine is 86 pounds (39 kg) lighter than the current model’s standard 2.5L engine, while delivering comparable performance.
The 2016 Malibu goes on sale in the fourth quarter of 2015. It will be offered in L, LS, LT and Premier trims, as well as a Hybrid model, which leverages Chevrolet Volt technology to offer segment-best estimated efficiency of 48 mpg city, 45 mpg highway and 47 mpg combined.
*Full Press Release at Link
General Motors
2015-06-17
5. A lighter engine
