1 - 17 of 17 Posts
Ok, I have a friend who has a 1995 Oldsmobile Royale 88 with the 3.8L in it, I believe its a K code. His serpentine belt had slipped of and then after placing it back on, broke. He had went and got a new belt and now does not know how it goes on. Does anyone have a diagram or instructions on how to replace it?? Please help!!!
I am not 100% sure on this model, but I believe there is a diagram located on the emission stickers under the hood. I know other GM models have this....usually by the A/C condenser just in front of the main radiator. Hope this helps!
There is no diagram to be found under the hood and he does not have the owners manual. I keep reading that the motor mount needs to be removed but from what I saw, it looks like that step can be skipped and the belt can be fed from the crank to the water pump, then the tensioner down to the PS pump and avoid the mount. Does anyone else have a clue? diagram?
Discussion Starter · #8 ·
Thanks edward...but...I already knew that. From what I recall, nothing siezed. However, on his way in, his power steering did go out but was working for the 30 seconds his car ran after we put the old belt on after it slipped of the first time.
Discussion Starter · #9 · (Edited)
Thanks for the diagram cadsrbest. I do recall seeing that in the ALLDATA demo on thier site. The main question I still have is do I have to remove the motor mount or whatever mount it is to feed the belt in or can the belt be feeded with the mount in place. From what I saw, it looks like that could work, but am asking here to get help to understand the proper replacement.
EDIT: I did read that post with the picture and apparently the mount does need to be removed. Is this true??
Work up from the Harmonic Balancer. If the pulley is smoot that means it is th back side of the belt, is it is ribbed, that means it is the face of the belt.
Usually it goes over the Water Pump on it's back first.
Discussion Starter · #11 ·
Okay. But, would starting there allow me to work around the stupid mount or not??
Yes:yup:
one bolt (access from the wheel well) has a spacer/sleeve. Always seems to go back together harder than it comes apart.
Yes:yup:
Across from the wheel well as in underneath the PS and water pump pulley on the block?? And then the mount should move out of the way?? Does know if there is a torque spec for the bolt??
UPDATE: Well, I talked to him tonight and I may be heading out to the car tomorrow to work on it. Still am wondering about a torque spec and if the location questions are correct. Thanks to all that have helped and to any that can provide more info.
3.8L - VINS 1 & K
Removal & Installation
Remove negative battery cable. Disconnect vacuum reservoir. Disconnect outer and inner accessory drive belts. On supercharged engines, disconnect heater hoses from pipes and pipes from engine. Using appropriate engine support fixture raise engine slightly to take weight off engine mounts. Remove two bottom bolts on front engine mount. Remove through bolt from front engine mount and remove mount. Remove belts from engine compartment. Installation is reverse of removal. See Fig. 9 and Fig. 11 . Tighten engine mount bolts to 65 Ft. Lbs. (87 N.m).
Sorry about the slow response
I'm trying to do the same thing to a 97 Regency with the 3.8L. I have taken the wheel off, the shroud, supported the engine with the jack, and taken the bottom motor-mount nut off.
How do I get that sleeve off? When I do get it off, that should allow me to put my new belt on, correct?
1 - 17 of 17 Posts
