Fort Wayne also does regular cab HD and LD.Perhaps Fort Wayne is retooling to build crew cabs also? I know that Flint can't keep up to the demand of the HD crew cabs. Fort Wayne builds extend cabs light and heavy duty models now.
More than rumor, the news is affecting the supply chain.I think it is just a rumor right now. Even adding a crew cab would not warrant such a long shutdown.
No new frame, that's for sure. They have the best in the industry, why change it?New Frame for HD's as well as new engines??
Stamping, huh? You know there were rumors that GM was considering aluminum bodies for K2XX (or maybe it was C2XX) but due to the financial crisis they stayed with steel. Maybe they are dusting off those plans, and will need to source aluminum panels from somewhere else. Permanent layoffs for a temporary shutdown might signifie something drastic.More than rumor, the news is affecting the supply chain.
GM has announced permanently laying off skilled trades at their stamping plants due to this.
How else are they going to get to 30k+ lbs? All from a new engine?No new frame, that's for sure. They have the best in the industry, why change it?
The factory hitch is rated to tow the max tow rating without replacing it. The frame is on the verge of F450-F550 in terms of its strength ratings. Shouldn't need too much tweaking to hit higher towing capacity. Just a stronger powerplant.How else are they going to get to 30k+ lbs? All from a new engine?
When touring the Lordstown plant they showed us where the Cruse already uses those techniques.Funny thing, did anyone notice Ford is using rivets and structural adhesives to assemble the F-150 body?
I have been told when GM does do a 4500/5500, the frame and front suspension will likely be similar to the current HD's. New Duramax will take care of the rest.The factory hitch is rated to tow the max tow rating without replacing it. The frame is on the verge of F450-F550 in terms of its strength ratings. Shouldn't need too much tweaking to hit higher towing capacity. Just a stronger powerplant.
For all of the talk about a future 4500/5500, we have seen neither hide nor hair of anything like them.I have been told when GM does do a 4500/5500, the frame and front suspension will likely be similar to the current HD's. New Duramax will take care of the rest.
GM has lost a fair amount of Silverado P/U fleet sales due to the lack of a 45/5500 Chassis Cab too. Ford and RAM are able to make a class 4/5 truck profitably, but you can't GM?GM messed up a good product when it quite using the C3500HD.
They gave it the newer 8.1 gas engine but should have included the Duramax and Allison transmissions as well.
They were first to the class4 party and first too leave. Amazing a the much smaller RAM can make a business case for a 45/5500 truck but GM can't.
Nothing yet other than some K2XX 3500HD cab and chassis models being tested. CEO Barra did speak of new entries into the full size truck line at today's press conference. Hopefully that means more than trim packages.For all of the talk about a future 4500/5500, we have seen neither hide nor hair of anything like them.
