Just ordered the ADD W1 for my Sierra.
Cheap insurance.
Cheap insurance.
Why are people with Chargers and Challengers discussing this?I see lots of catch can talk at Charger and Challenger forums. The idea makes sense to me. No oil no foul.
Because runoff goop going back into the intake is runoff goop going back into the engine, no matter what.Why are people with Chargers and Challengers discussing this?
There aren't any DI engines in those cars.
True.Because runoff goop going back into the intake is runoff goop going back into the engine, no matter what.
Hence the catch can. I should do one for my Soul.True.
I know Chrysler is working on a cooled EGR for their engines for use when they go DI. Supposed to condense the vapors before they get to the intake valves.
But all that says to me is the goop is going to be stuck somewhere else instead of on the intake valves.
Not without a permit :nono:Hence the catch can. I should do one for my Soul.
Once you collect a couple of ounces, you can set it on fire in your back yard, thus disposing of it in an environmentally harmonious manner.![]()
No problem. Evidence will be Up In Smoke before anyone knows Jack.Not without a permit :nono:
Look. Think what you like. I don't care to try to convince you. If you think it's a bad idea, fine. Don't friggin buy one.So a $20 catch can was deemed to expensive to save a couple thousand dollar engine....and it could be emptied at every oil change....how simple....Or maybe Not need!!!!!
Why would a manufacturer spend additional money to add a catch can at X dollars per vehicle, which then is another component needing regular service (while customers are demanding their vehicles require as minimal maintenance as possible)?So a $20 catch can was deemed to expensive to save a couple thousand dollar engine....and it could be emptied at every oil change....how simple....Or maybe Not need!!!!!
bah, I helped my buddy swap out the transmission in his Reatta, in a snow stormGot mine in the mail the other day.
Just need to wait for the thaw to get it installed. This winter has been the worst in memory![]()
Why indeed?Why would a manufacturer spend additional money to add a catch can at X dollars per vehicle, which then is another component needing regular service (while customers are demanding their vehicles require as minimal maintenance as possible)?
The engine with the world's worst PCV system will still make it through the warranty period with a sludged up intake costing mpg and horsepower without blowing up. Why then would the manufacturer spend more money to design and install any type of catch can?
Yes we can!What your suggesting is that ALL automakers don't care about their customers beyond the warrenty period! They want to destroy any good will to save $20 per engine....are you insane?
