1) What disorder is generated within a motor when this is shaking?
2) What kind of engines have a greater compression and why? (gasoline engines)
3) What's the main difference between a diesel engine and a gasoline engine?
4) What means and what's the use of KOEO and KOEF?
5) What is the meaning of MAF, DOHC, ABS, V-TEC?
If I didn't translate them correctly here is the original questtionaire:
1) Qué desorden se genera dentro de un motor cuando este cascabelea?
2) Qué tipo de motores tienen mayor compresión y porqué? (motores a gasolina)
3) Cual es la principal diferencia entre un motor de gasolina y uno de diesel?
4) Qué significa y para que se utiliza el KOEO y KOEF?
5) Qué significan las siglas MAF, DOHC, ABS y V-TEC?
I hope you can help me guys!
