MALIBU 2008 -- How to remove HEADLAMP ???
50872 Views 12 Replies 8 Participants Last post by  hattwrench
Well i want to remove the headlamp from my MALIBU 2008 LT2 to get a HID kit ... but
i don't know how to remove the headlamp, i remove the plastic trim ... but ton only screw i see is the Adjustment light screw ....
Help me please ( with picture please )
Thank you
1 - 13 of 13 Posts
Thank you
Your owner's manual should have something in about changing the headlight bulbs. Are you changing the bulbs or the whole unit?
I don't think that I've seen an HID Malibu....it would look good with them.
Well int the manual at page 5-48 start Bulbm replacement
but no information to HOW to remove the bulb ... was mentionned only the type of the bulb ...
well only back up and plate light was mentioned..
Me i want to change Head light ... change bulb h9 - h11 to a HID xenon kit
Headlamp Replacement
Callout
Component Name
Preliminary Procedure
Remove the front bumper fascia upper bracket. Refer to Front Bumper Fascia Bracket Replacement .
1
Headlamp Screw (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tip
Secure the headlamp fasteners in sequence, as indicated.
Tighten
3 N·m (27 lb in)
2
Headlamp Assembly
Procedure
  1. <LI type=1>Pull forward on the outside edge of the headlamp in order to release the up and down locator tabs on the backside of the headlamp. <LI type=1>Pull forward on the top inside edge of the headlamp to release the inboard up/down locator. <LI type=1>Pull the headlamp assembly down. <LI type=1>Pull the headlamp assembly forward far enough to access the electrical connection. <LI type=1>Disconnect the headlamp electrical connector from the forward lamp harness connector. <LI type=1>Remove the headlamp assembly.
  2. Aim the headlamps after installation. Refer to Headlamp Aiming .
Front Bumper Fascia Bracket Replacement (Upper)
Callout
Component Name
Remove the front bumper fascia. Refer to Front Bumper Fascia Replacement .
1
Front Bumper Fascia Bracket Bolt (Qty: 2)
Tighten
6 N·m (53 lb in)
2
That is pretty complicated for a headlamp.
Sorry sahdowflare for not responding sooner, but I was terribly busy this weekend at my second job!
Hope this helps...
OMG .. lol it's a little harder then my AVEO 2004 lolll well If I understand the headlamp remove method ... it's
I need to remove the plastic cover ..
after the bumper ... then i get access to the headlamp :|
loll I will have fun for this ... loll
After i Finish my installation i will add Some OLD Malibu - My new Malibu with all my mod ...
funny---- GMCsonoma to the rescue again.
I asked a similar question- but for a 2008 Buick Lucerne- how to replace the bulb.
he also posted similar pics- Id have to remove the entire bumper and a few other parts to remove the headlight assembly.
I started to remove stuff. when it came time to loosen the bolts holding the bumper to the quarter panel- I was laying on my back- and looked up---- and saw the headlight bulb....
hopefully you can do what you want to do without going thru the whole process....
I got lucky that I had small hands and was able to reach up and change the bulbs that way.in the pic below- I was laying on my back on the floor- and I looke up to see the headlamp assembly and bulb- I did have to remove a large splashshield under the car to see this...
Wow, you are not worried about Warrant for the Car?
Well i'm not worry for warrant ..
Now my malibu have 2x HID 6000 K with a 55 WATTS ... not a 35 watts HID kit ...
I'm brighteness then a BMW, LEXUS or anyone another car ...
I will send more picture soon ..
but Question
on Malibu LTZ did the fog light fit on a Malibu 2LT ??
the part
25905343 $62.58 $38.40
25905344 $62.58 $38.40
25829654 $112.76 $70.37
25905343 & 5344 fit on a malibu 2008 2lt ??
Or i need to buy a new bumber ??
Did you ever buy the fogs Shadowflare99?
check out this video http://carcarekiosk.com/video/2008_Chevrolet_Malibu_LS_2.4L_4_Cyl./lights/headlight
it shows how to get the housing out and change the headlight
they also have videos for the high beam, parking light, daytime running light and turn signal (same procedures, different bulbs)
1 - 13 of 13 Posts
