1 - 20 of 21 Posts
This is my 2nd entry to replace my Armoured H-Zero.
It's the Hummer H3 Venom Sport Wagon.
It is to H3 what the Ford Range Rover Sport is to Ford's chunky Discovery. Note also about the design; that apart from it's externally more sporting appearance, it's slim a,b and c pillars will give it not only a better view but a more open and airy feel consistent with a more sporting drive.
Oz is home to 10 of the ten most venomous spiders and snakes. Here's our RedBack Spider:
Is it better brightened up a bit?
A comparison H3 pic:
fp115 said:
I actually like the slant in the windows a lot more than having them in a straight line.
Thanks fp115,
I created the roof from this 2 door VW golf hatch pic.
I thought the rising waistline would give it a sporting look without sacrificing interior load space.
I also added a subtle flowing coke-bottle accent line just below the window glass which curves up from the front lights, pinches in under the door windows, and then with a little hip over the rear wheels curves down to the taillights.
Just thought Hummer could use some subtle curves and a slight wedge shape.
CRBoyd91 said:
It reminds me of a raised Dodge Magnum.
Hi CRBoyd91,
Thats the look I was going for.
04Colorado said:
Sweet. When I first saw it, I thought Lambda Hummer.
Hi 04Colorado, Thanks.
Not really Lambda, as that platform has a lower ground clearance. Here though I have retained the H3's rugged platform and offroad capability.
I hate to even use the R-word (or H), but the Ridgeline's chassis, from what I've read, is pretty stout. Maybe GM could beef up the Lambda's suspension/chassis to use in an application for Hummer. No rock crawler, but it could definitely eat up some trails, and be family-friendly.
It reminds me of an Eagle...
Wow man that thing looks like a serious Black mafia Truck!
Sweet.
Discussion Starter · #12 · (Edited)
Rex Raider said:
I don't really like it. What's the difference between this and an H3? Is it just supposed to be softer?
Hi Rex,
You know Ford's chunky square Discovery 3:
Well the H3 Venom is to the H3 what Ford's Range Rover Sport is to Discovery: a sport wagon built on the Discovery frame.
Additionally, in case your question was literal. Here is a comparison of the two together so you can see that it is a radical redesign, not a photoshop softening of the original. Note also about the design; that apart from it's externally more sporting appearance, it's slim a,b and c pillars will give it not only a better view but a more open and airy feel consistent with a more sporting drive. The two would be light years apart in their feel behind the wheel and driving experience. The H3 is designed to be a slightly claustrophobic slab sided box; this is designed to wrap the car in curved glass and connect you with the outside evironment.
Discussion Starter · #15 · (Edited)
roberto57 said:
Those wheels look awesome.
Hi roberto57,
Thanks. They look way better after I modified them to fit the Hummer I think than in the original pic I got them from:
This is the same Golf pic I got the roofline from. I had to change their vertical angle and stretch them horizontally. I also enhanced them a bit with a red airbrushing and cleaned them up digitally.
Essentially I morphed this pic and a pic of a standard black H3 together, along with a lot of mucking about, to create the Venom.
Good work. I like this H3 Venom!:D
I like it, but the slant on the windshield is to much, it reminds me of a Jeep Liberty, when you get in it feels like your face is right up against the windshield, other than that it looks sweet!
1 - 20 of 21 Posts
