1 - 2 of 2 Posts
hi
i am looking for some info on removal of the heater core in a 1995 olds 88. i found some info on autozones website, but not sure about it. is there dash removal to be done on this car, or can it be done by some access panels. i have no GM knowledge, or shop books. i am trying to help a friend fix their car. i have done heater core removal before but not a GM car. thank you for any help or advice.
i have heard some GM cars are easy to do.
thank you again to anyone for any answers
eddie
Heater Core Replacement
Removal Procedure
Tools Required
J 37097-A Hose Clamp Pliers
Drain the cooling system. Refer to Cooling System Draining and Filling in Engine Cooling.
Remove the heater hoses (2) from the heater core using the J 37097-A .
Remove the right sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gauges and Console.
Remove the I/P compartment. Refer to Instrument Panel Storage Compartment Replacement in Instrument Panel, Gauges and Console.
Remove the temperature valve actuator. Refer to Temperature Actuator Replacement .
Remove the HVAC programmer (C68). Refer to Programmer Replacement
Remove the heater core cover retaining screws.
Remove the heater core cover.
Remove the heater core retaining screws.
Remove the heater core.
Installation Procedure
Install the heater core into the vehicle.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the attaching screws.
Tighten
Tighten the screws to 1.4 N·m (12 lb in).
Install the heater core cover.
Tighten
Install the HVAC programmer (C68). Refer to Programmer Replacement
Install the temperature valve actuator. Refer to Temperature Actuator Replacement .
Install the right sound insulator. Refer to Instrument Panel Insulator Panel Replacement - Right Side in Instrument Panel, Gauges and Console.
Install the I/P compartment. Refer to Instrument Panel Storage Compartment Replacement in Instrument Panel, Gauges and Console.
Install the heater hoses (2) to the heater core using the J 37097-A .
Fill the cooling system. Refer to Cooling System Draining and Filling in Engine Cooling.
1 - 2 of 2 Posts
