Hey guys, first time here, so just hoping you can help a guy out!
What I have is a 2k4 GP GTP Comp-G, and I am in need of new struts..
I have gone to the local GM dealer and got PN
Front : 88955411 @ $174.78 per
Rear : 88955413 @ $178.06 per
I was just curious to weather there were cheaper alternatives to the GM product.. as I found some Monroe struts that were only around $80 a piece.
Being a Comp-G I'm not sure if those monroe's are up to FE3 Spec.. and if they are not, will it hurt putting them on even though they belong on a regular GTP? I don't do any hardcore cornering or anything like that, so the softer ride probably wouldn't bother me.
Any information/part numbers would be greatly appreciated!
Thanks for the help!
Discussion Starter · #2 ·
Also - My main problem is a rattling noise coming from the front when going over bumps. I think I have it narrowed down to it being the front driver's upper strut mount.. but do you guys think otherwise? Just a metal to metal rattle sound...
I replaced the LIM gasket, and on up.. and everything should be tight.. I guess I never really noticed when the noise started..
And I figured if I'm going to take the strut apart, I midas well just replace all the struts right away.. (97000 miles)
