1 - 12 of 12 Posts
Editor
CTS
--New--
2.8 DOHC V6 (replacing 3.2)
Sport Package
Getrag 6-Speed manual Transmission (Avalible on ALL)
Escalade
--New--
Redesigned interior featuring chrome bezels
Walnut wood (replacing Zebrano)
ESV
--News--
20" Chorme Rims standard!
Thats all for now....But wait....
I wonder how "redesigned" the interior is, and if this (hopefully) will carry over in some form to the Suburban / Silverado? (They sure need it)
What's with the CTS engine? Some lower priced base model? The 3.2 was only still in the lineup so GM could offer a manual transmission, I thought. If the 3.6 will be made available with a manual as promised for 2005, I figured they'd drop the 3.2 and go all 3.6. Neat "2.8L" engine tho. Hadn't heard of that. Hope that gets used in some other GM vehicles....perhaps a Saturn L-series replacement?
"Export" models of the CTS have had a 2.6L version of the previous 3.2L V-6 since introduction. We just didn't see it in the USA, but it's been in the parts database from day one. Initially, the 3.2L V-6 is being used with manual trans CTS V-6s while the new 3.6L DOHC is with the automatics.
I would not be surprised if the V-6/manual trans variation is dropped as Lincoln ended up dropping the manual trans option on the Linclon LS due to not enough sales to justify it. CTS export models might be different due to market and fuel economy issues, though.
Enjoy!
NTX5467
Some more detailed info on STS:
2005 Cadillac STS:
Models-
V6 RWD
V8 RWD
V8 AWD
Interior-
Aluminum Trim Package, premium aluminum trim, includes
center stack and console
Cruise control, adaptive, sophisticated radar
transceiver automatically adjusts speed to maintain
preset following distance, includes telltale in head-up
in reconfigurable head-up display
Head-Up Display, reconfigurable, includes digital
readouts for vehicle speed, selected gear, adaptive
cruise indicator, radio information, high-beam
indicator, fuel level, six languages available (English,
French, German, Italian, Japanese, Spanish)
Keyless Access, includes keyless ignition which is
engaged with push button start, and 2 remote
transmitters which enable passive entry on both front
doors and trunk, and remote start capability
Steering wheel, mounted controls, includes controls for
sound system, HVAC system, voice recognition and
Adaptive Cruise Control (if equipped)
Wood Trim Package, includes real eucalyptus wood on
steering wheel, shifter knob, center stack and console,
IP spear molding and door pulls
Stereo-
ETR AM/FM Bose 4.0 with CD player, includes Radio Data
System and 8 speakers
ETR AM/FM Bose 4.0 with in-dash 6 disc CD changer,
includes Radio Data System and 8 speakers
ETR AM/FM Studio Surround Sound Bose 5.1 with in-dash 6
disc DVD changer, includes Radio Data System,
seek-and-scan, digital clock, automatic volume
compensation, TheftLock, weather band, digital signal
processing and 15 speakers, rear passenger A/V jacks
disc DVD changer, DVD-based Advanced Navigation,
includes Radio Data System, seek-and-scan, digital
clock, automatic volume compensation, TheftLock, weather
band, digital signal processing and 15 speakers, rear
passenger A/V jacks
Exterior-
Glass, laminated front side for quiet car
characteristics
Exhaust outlets, dual chrome-plated tips
Headlamps, halogen, Tungsten, windshield wiper
activated, includes Twilight Sentinel and flash-to-pass
feature
Headlamps, Intellibeam, automatic low/high beam control
Headlamps, Xenon, high-intensity discharge, windshield
wiper activated, includes flash-to-pass and headlamp
washers
Spoiler, decklid
Rear Parking Assist, Ultrasonic, includes rearview LED
display and audible warning
Tires, P235/50R17, Michelin, S-rated, all-season,
blackwall
Tires, P235/50R17 front and P255/45R17 rear, Michelin,
V-rated, all-season, blackwall
Tires, P235/50R18 front and P255/45R18 rear, Michelin,
W-rated, all-season, blackwall
Wheels, 2 - 17" x 7.5" (43.2 cm x 19.1 cm) front, 2 -
17" x 8" (43.2 cm x 20.3 cm) rear, cast aluminum,
painted, 7-spoke
polished, 7-spoke
Wheels, 4 - 18" x 8" (45.6 cm x 20.3 cm) cast aluminum
polished, 9-spoke faceted
Wheels, 4 17" x 7.5" (43.2 cm x 19.1 cm) cast aluminum
painted, 7-spoke
Wheels, 4 - 17" x 7.5" (43.2 cm x 19.1 cm) aluminum
polished
Wipers, Rainsense
Mechanical-
Brakes, Panic Assist, senses high impact braking and
assists with braking maneuvers
Driver Shift Control
Engine, 3.6L V6 VVT (260 HP [193.9 kW] @ 6500 rpm, 252
lb.-ft. [340.2 N-m] @ 2800 rpm)
Engine, 4.6L Northstar V8 VVT, SFI variable valve
timing, Northstar (320 HP [238.6 kW] @ 6400 rpm, 315
lb.-ft. [425.3 N-m] @ 4400 rpm)
Limited Slip Differential
Performance Cooling Package, includes P/S cooler,
mechanical engine driven fan and 2-80 watt pusher
electric fans
Premium Steering Gear, ZF
StabiliTrak
Seating-
Front, bucket Nuance Leather Seating Surfaces
Front, bucket Tuscany Leather Seats
Heated and Cooled Seats
Suspension: 4-wheel independent w/Magnetic Ride Control
Lighting, illuminated entry and exit, includes courtesy lamps and entrance lamps in base of door and under IP
Steering wheel, leather-wrapped rim, heated
Brakes, 17", performance
Fuel capacity, approximate, gallon (liters) 17
Colours, Light Gray1, Ebony1, Light Cashmere2
1 - Light Gray or Ebony Interiors include dark
eucalyptus wood trim
2 - Light Cashmere interior includes medium eucalyptus
wood trim
Exterior Colours-
Blue Chip
Red Line
Black Raven
Silver Smoke
Sand Storm
Moonstone
Light Platinum
Silver Green Metallic
White Lightning
Dimensions-
Wheelbase 116.40 (2957)
Overall length 196.30 (4986)
Body width 72.60 (1844)
Overall height 57.60 (1463)
Front track width 61.80 (1570)
Rear track width 62.30 (1582)
Head room, front 38.70 (983)
Head room, rear 37.90 (963)
Shoulder room, front 58.60 (1488)
Shoulder room, rear 57.40 (1458)
Hip room, front 54.60 (1387)
Hip room, rear 55.60 (1412)
Leg room, front 42.60 (1082)
Leg room, rear 38.30 (973)
Originally posted by Z28x@Dec 2 2003, 12:29 AM
Why would they want to sell the CTS with a weaker engine than the 3.2L in the US?
it's only about 20HP lower than the 3.2L and torque is about the same. i'd still feel shafted, but you're still getting a good car.
anyway, i thought the 2.8L V6 was a japan-only engine for the CTS. is this info correct? maybe someone got confused and made a mistake while presenting their info? please tell me this is the case.
I don't understand why you wouldn't want to give the consumer as many choices as possible (without hurting yourself). If a 2.8 CTS can compete with a 325 on price and performance while offering more room that will help people who can't afford more than 30k.
Brian
1 - 12 of 12 Posts
