You're kidding right? I hope so because weight has a HUGE effect on gas milage. What do you think effects rolling resistance (besides tires)?Originally posted by 87GN&98VET+Apr 20 2004, 04:51 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (87GN&98VET @ Apr 20 2004, 04:51 PM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-desmo9@Feb 27 2004, 12:54 PM
Weight of a truck has almost no bearing on highway mpg, where the low-20s figure comes into play. Aerodynamics, rolling resistance, and gearing are about it.
Diesels cost more because the cylinder pressure is so much higher that premium materials / components are required. What I don't get is that if the OEs put as much $$ into developing SI engines such as 42 volt systems, electric water pumps, steering pumps, AC compressor, etc, pneumatically controlled valves, regenerative braking, the list goes on - the economy might be as good or better than diesels. Gain efficiency by increasing volumetric efficiency through turbocharging and reduce pumping loses. [/b][/quote]
No, no kidding. Weight has a negligible effect on rolling resistance, especially negligible compared to wind resistance. Weight impacts city mileage figures, but as long as you're fairly steady on the throttle and keep appropriate pressure in the tires, weight has very little impact on the highway figures. If you don't believe me, throw 1500 pounds in the bed of a pickup, pump up the tires a bit, and hit the highway.
