1 - 20 of 46 Posts
First Drive: 2009 Dodge Ram Pickup 1500
Prepare yourselves, fellow truckers, for a brand new day. No more will you be surprised by a sideways leap of the ass end of your truck when you encounter midcorner bumps or cross railroad tracks.
No more will your insides turn into a quivering bowl of gelatin as you traverse a lumpy freeway. And no longer will you and your passengers quiver at the sight of a washboard dirt road or a poorly maintained driveway.
Nay, these things will no longer happen, because the 2009 Dodge Ram 1500 pickup has been healed!
Can I get a hallelujah?
Someone Had To Do It
Pickup truck suspensions have needed help since Day One. After all, one of the most common put-downs used to describe an uncomfortable ride is, "This thing rides like a truck." The all-new 2009 Dodge Ram 1500 Pickup most certainly is a truck, from the tip of its optional 390-horsepower 5.7-liter V8 Hemi to the tail of its 9,100-pound maximum towing capacity, but it no longer rides and handles like the usual sort of truck.
A set of gargantuan coil springs now supports the back half of the new Ram, improving ride and stability while miraculously preserving the payload and towing capacity of the 2008 model. If the competition doesn't already have prototypes and test mules running around with this setup at their respective proving grounds, they'd best get on the ball.
Full-size SUVs ditched leaf springs for coils years ago, but they've remained on pickups for one big reason: They're cheap. Stubborn traditionalism probably had something to do with it, too.
A leaf spring is inexpensive because this simple sandwich of steel simultaneously locates the axle while it shoulders the load. But trying to do everything at once creates problems. The locating bushings and shackles can't adequately control deflections, making rear wheel alignment a matter of faith. And the friction between the overlapping leaves fosters a jerky stick-slip motion of the rear axle, making it difficult to keep the tire rubber on a bumpy road. Oh, and they're heavy, too.
The Ram's use of coil springs improves all of the above. Here four trailing links and a Panhard rod accurately locate the rear axle in three dimensions. This leaves the coils — which have no rubbing or sliding surfaces to create friction — free to support the back of the truck. As a bonus, this setup allows better packaging of the shock absorbers (parallel, instead of staggered), enables the fitment of a rear antiroll bar (every new Ram 1500 has one), provides increased off-road axle articulation and saves about 40 pounds.
Coil spring rear suspension is a good deal.
Behind the Wheel
Dodge has not been tentative in its confidence about this. Our initial drive of the 2009 Dodge Ram 1500 had been prepared to send us across aged asphalt back roads that had been repeatedly patched over the years with shovelfuls of asphalt and then tamped inexpertly by hand. We also had access to the Ram 1500's every competitor: the Chevy Silverado, Ford F-150, Nissan Titan and Toyota Tundra. And the test trucks we drove were even fitted with P275/60R20 tires, the option least friendly to ride.
It wasn't even close. The other trucks twitched, shook and shuddered over the lumps, sidestepping a couple of inches over one particular midcorner bump. Not so with the Ram; its composure remained resolute. Oh, sure, we could still feel the wretched pavement, because the coil springs still need to be stout enough to handle a payload and the rear axle is still a solid one and therefore still carries the unsprung weight liability of that design. Yet rear impacts were substantially better managed and more in sync with the front suspension.
But the Ram driving experience isn't all rosy. The effort level of the rack-and-pinion steering tends toward the light side, and what effort build-up there is doesn't correlate directly to the level of cornering force being generated by the tires. We found this lack of direct feel disconcerting at times, especially during sweeping turns. It's all relatively benign, but there is no revolution to report here.
Ram prototypes reportedly spent far more than the usual number of hours in the wind tunnel, reducing the drag coefficient to improve fuel consumption. The new 1500 certainly looks sleek and slippery at a detail level, with uncommonly small gaps (for a truck) between the front bumper and the grille, tight-fitting triple-sealed doors and rubber gaskets between the cab and bed. But wind noise did not get taken to a whole new level in the process; our pre-production Laramie Crew Cab 4x2 sample vehicle sounded a tad gusty when cruising at 60 mph.
More Powerful Engines, Fractionally Less Thirsty
Changes to the 5.7-liter Hemi V8 have led to a significant increase in output. Variable valve timing, variable-length intake manifold runners and a higher compression ratio help the revised mill make 390 horsepower (up from 345 hp) and 407 pound-feet of torque (formerly 375 lb-ft).
The extra grunt contributes to increased efficiency by allowing the Multiple Displacement System (MDS) cylinder deactivation to operate in V4 mode more readily. It can also generate a claimed time to 60 mph of less than 6.0 seconds when mounted in the regular cab short-bed 4x2 R/T. Or it'll tow 9,100 pounds in a short-bed SLT 4x2 with the optional (and less fuel-friendly) 3.92:1 rear-end gears.
Optional towing gear ratios are necessary, however, because the new Ram still uses a five-speed automatic. A truck with a six-speed can offer high towing capacity without forcing the customer to buy and live with a less economical rear end.
Still, a small fuel consumption benefit has been realized. Tentative 2009 Dodge Ram 1500 EPA ratings for a 5.7-liter Hemi-powered 4x4 are 13 mpg city and 18 mpg highway, up slightly from 13 mpg and 17 mpg. The same engine in a 4x2 yields no apparent improvement, as the expected EPA rating for the new truck is the same as the 2008 model: 13 mpg city and 19 mpg highway.
The smaller and less powerful 4.7-liter V8 is predicted to have the same EPA ratings as the 5.7 Hemi V8, but the 4.7-liter V8 is a flex-fuel engine that can run on E85. Diesel power and gasoline hybrid powertrains are in development and will be available in 12-18 months.
New Crew Cab
As before, Dodge offers three cab configurations and three bed lengths for the 2009 Ram 1500. The regular cab and Quad Cab are familiar, but the too-big Mega Cab has been replaced with a more traditionally sized Crew Cab. Our Crew Cab sample still offered a generous 39.4 inches of rear legroom, mostly because the huge storage area behind the seat is the bit that was lopped off.
Dodge makes up for this storage loss in several ways. First, the rear seat bottoms flip up to reveal storage compartments and there are two lined wells beneath the rear floor mats sized to hold a six-pack and ice.
A few weeks after the initial Ram launch, the Crew Cab will be available with an optional RamBox, a 5-foot-7 bed with saddlebag-style lockable and lighted storage bins with a combined storage capacity of 7.4 cubic feet, big enough to swallow a set of golf clubs on each side. These bins make the inside of the bed resemble that of a step-side, but it is still wide enough for a sheet of plywood or drywall. Twelve vertical slots are stamped into the inner bed walls, into which a bed divider can be clamped to keep items fenced in.
Interior Improvements
Dodge focused considerable effort on the interior as well. Improved materials cover the handsome dash, and our Ram Laramie had front bucket seats and a console-mounted shift lever. A three-across front seat and column shifter are still in the mix for those who want it. All seats benefit from improved sculpting and attention to detail.
Rear-seat video and a 10-speaker surround-sound audio system are on the options sheet, as are Bluetooth, navigation, a rear back-up camera and Sirius TV. The hard-to-use touchscreen audio head unit is, unfortunately, also a carry-over item. It has an auxiliary jack and a USB socket, but doesn't provide full iPod control.
Several trim levels are offered, beginning with the work truck ST and moving through SLT, TRX, Sport and finally to the top-line Laramie. A short-bed regular cab 4x2 in ST trim with the 3.7-liter V6 is expected to go for less than $20,000. In Sport trim with a 5.7-liter Hemi and the R/T package, that same truck might go for around $34,000. We spent a lot of time in a loaded 4x4 Laramie with the 5.7-liter Hemi, RamBox and the kitchen sink, and it carried an estimated price of almost $48,000.
Really New
Most of the stuff that's new about the 2009 Dodge Ram 1500 pickup is what you'd expect: new sheet metal, a clean-sheet interior and some engine revisions are combined with some carry-over bits and pieces.
But the bombshell that makes this truck truly all-new is the use of a coil spring rear suspension. It took a leap of faith — combined with a bucket-load of engineering — for Dodge to get to this point. But now that we've driven it, we're believers.
At least we believe enough to be excited about the prospect of getting a production version in our hands for a thorough vetting. We may be believers, but we're not fanatics — not yet, anyway.
Source: http://www.edmunds.com/insideline/d...=131095?tid=edmunds.il.home.photopanel..1.*#3
Pictures: http://www.edmunds.com/insideline/do/MediaNav/articleId=131095/firstNav=Gallery/photoId=61801
First drive by Motortrend at Link: http://www.motortrend.com/roadtests/trucks/112_0808_2009_dodge_ram_first_drive/index.html
Review by Pickuptrucks.com: http://www.pickuptrucks.com/html/2009/dodge/ram/first-drive/2009-dodge-ram-1500-first-drive-1.html
Discussion Starter · #2 ·
I actually like the looks of the new Ram! And the interior looks really good too! I think GM needs to put the shifter in the center counsel like Dodge and Ford!
Unfortunately for Dodge, and to a lesser extent Ford, these are some really good products comeing at the worst imaginable time. GM is going to have to keep it's deals going on it's trucks to stay competitive with the new offerings from Dodge and Ford in this ever tightening market.
In all honesty, if this were 5 years ago, I'd save up a little extra money and buy myself a 5.7l Hemi Rear wheel drive Ram for a sport truck.
Alas, with fuel prices the way they are, I am not buying ANY mid or full sized SUV or Truck. If we were back below $2.00 a gallon though, I think this would be my next vehicle, I like it that much.
You know what I find sad...when people say a truck rides like a truck. What else is it going to ride like?? Trucks were never meant to haul tons of people to grocery stores. Trucks ride like trucks because trucks are meant to carry big loads and be capable and go off road etc... why else do they ride like trucks? If you want a car like ride, then buy a car. If you want to haul tons of people, buy a car, if you get groceries, buy a car.
I agree, bad timing. But unless they're going to get out of the pickup business altogether, they need competitive product to keep from losing too much marketshare to competitors. The new suspension setup is really innovative.
Sorry, but with some image conscious people, the idea that they should buy a car if they want something that rides like a car is just too kinky for them to deal with. Similarly, one could argue until blue in the face that if you want something that handles like a sports car, one should buy a sports car. Again, for some people, that's just strange.
The coil spring thin is interesting, as my mom's '67 C-10 had them at the rear, I remember her buying a set of heavy duty rear springs for it, which she never managed to get installed...
LOVE the size of all the Dodge logos on the outside and inside of the Ram!!!!!!
I saw a new Ram in the wild today. It looked pretty nice. It appears they have made a real class leader here.
The '09 Ram looks great, and the rear suspension geometry is interesting.
Sure out-looks the GMT-900 pickups.
We'll see if the market responds to the new Ram. Chrysler LLC sure could use a break.
Good point, and we shouldn't forget then the next-gen Nissan Titan planned for 2010-2011 will use the Dodge Ram platform, so it might have some of the feature then the Ram have.
Great looking and engineered pick-up. It will never sell as well as the current model,however,it should garner a higher percentage of the total market;especially at GM's expense. I believe it is possible that Dodge may eventually outsell Chevy,unless, GM does midcycle re-design of its ugly grill and rear fenders.
I love this truck and if I were in the market for a truck, I'd definitely go with the new Ram. I was behind one with a Manufacturers plate a month or so ago. It was a nice two tone brown quad cab with the Laramie package. But what really caught my eye as being distintive were the dual exhaust pipes. The luxury features on these new trucks are just unbelievable as well. In my opinion, as far as looks go anyway, I like it better than the upcoming 09 F150 and Silverado. I absolutely agree the shifter on the GMT 900's needs to be moved to the center console. Although some people like it so...that's the decision GM went with. Unfortunately for all three, GM, Ford, and Chrysler, the timing is terrible as far as investing development cash in all new trucks. It is like the perfect storm for low MPG vehicles with the economy and high gas prices sliding at the same time. This appears to be one vehicle that Chrysler has gotten right so hopefully they have the same in their product pipeline.
Is there a reason other automakers haven't used coils on the rear on trucks other than cost? Surely its been thought about if there aren't any negatives other than cost. How hard would it be to adapt the rear suspension from a Tahoe to a Silverado? The front looks good, the sides look strange to me, and I think the bed storage boxes are stupid. How much harder will it be to reach into an already taller bed over those? I think GM can stay competitive with this and whatever the "All-new" (refreshed) F150 throws at it with a refresh.
1 - 20 of 46 Posts
