Sure it's relevant. That's a 35% increase, and it's likely Toyota could have done quite a bit more with the Prius if they were going to price it that high. Or to put it another way, 7,000 British pounds can buy a ton of gasoline, even at European prices.
Prius/5-series (advantage)
Head room front: 39.1/39.1
Head room back: 37.1/38.1 (1 inch BMW)
Leg room front: 41.9/41.6 (0.3 inch Toyota)
Leg room back: 38.6/36.0 (2.6 inches Toyota)
Shoulder room front: 55.0/57.3 (2.3 inches BMW)
Shoulder room back: 52.9/57.1 (4.2 inches BMW)
Trunk space: 14.4/14 (0.4 cubic feet Toyota)
Cabin space: 96.2/99.0 (2.8 cubic feet BMW)
The 5-series is not substantially larger.
The 5 series has a substantially larger frontal area and higher drag co efficient.
Also .... the Prius sales presentation of interior room .....does not not include none measured space OR measured space efficiency - both of which make a big difference - there is no comparison putting 4 people in a 5 series versus a Prius and driving a route like this.
It also fails to account for all the other 5 series pluses - things like active/passive safety, better A/C and driving dynamics to name just few.
In fact, other than overweighting a smaller footprint in a tight parking stall there is no summary comparison to be made between the two that doesn't massively favor the 5 - which is as it should be given the purchase prices involved.
The another way to see the real topic - BMWs diesel powertrain superiority versus Toyotas HSD - BESIDES SALES RESULTS anywhere the two compete with each other is to consider if a scaled down BMW powertrain was installed in the Prius.
Given the realities of Prius driving dynamics or really non dynamics a 1.4-1.6L BMW diesel/6MT installed in a Prius would not only substantially improve fuel economy it would also help improve the driving experience as well.
And for those that want to continue the charade that in an overall sense somehow a Prius is even remotely comparable to a 520d - except to illustrate just one of the 50+ superior passenger car diesel choices available in Europe ...... then lets do the same thing - going the other way.
Go 'compare' - with the same twisted logic the current Edsel in the making Lexus LS 600 h - in either length to the 520d.
Although also silly (primarily in regards to the L's backseat only) its still more sensible than a Prius versus 520d comparison.
Of course, you could compare the Prius to the LS 600 h on interior volume and trunk space..... and SOB - no doubt about it using. Prius 'logic':lmao: Toyota biggest mistake regarding hybrids appears to be located largely in the Lexus line up.
The GS series in Europe and elsewhere is the most logical match up to the 5 series -and whether gas versus gas or hybrid versus diesel it is again no contest anyway you want to measure it - including fuel economy on diesels versus Toyota HSD.
This 'unfair' to BMW and diesel comparison - which they won anyway - helps explain part of Toyota's powertrain predicament 'moving forward'.
BTW, somebody made the point about a Prius not doing so well on the Highway - boy you aren't kidding.
Back in '05 I took a somewhat different roadtrip in an '04 Prius. It involved a close to full load (correctly distributed) under high and hot conditions with strong wind 'at speed' - uphill - when the Prius could keep up.
The Prius indicated 22 plus mpg. Careful PIA hand measurement indicated 18 - 18.40 so that made sense all around. One of the other cars was in the convoy was a '03 Buick Lesabre equipped with the 3.8L v6 and the expected 4speed AT. This was the best comparison piece in our little convoy because when the Prius 'overheated' (HSD battery) and became essentially unusable the Buick stayed behind and idled a good deal of the time with the A/C on - while we waited..... partially on a hunch.... and with prayer for the Prius to cool down. The Buick, also fully loaded (incorrectly) and later overloaded - measured out at 22 plus mpg.
This was much more impressive then the Prius - which had all of its load sans driver and tote bag shifted primarily to the Buick for the last 1/4 of the trip. It was then run very uncomfortably without radio/electrical load and intermittent A/C.
The older M5 which was along for the ride and driven much harder still - with more idle time managed something over approx. 15/16 mpg which when all is said and done outpointed the Prius as well.
