Last month, General Motors released EPA-estimated fuel economy figures for one of the new, turbocharged 2.7-liter inline-four's applications: the two-wheel drive version of the 2019 Chevrolet Silverado and GMC Sierra pickups.
Despite boasting 310 horsepower and 348 lb-ft of torque, the engine's combined estimated fuel economy of 21 miles per gallon left many wanting more. Now that we have EPA figures for the rest of the line, it's no surprise to see that figure serve as an MPG high water mark.
(Kudos to the eagle-eyed Bozi Tatarevic, who noticed the new figures)
In two-wheel drive applications, the 2.7-liter, which comes standard on LT and RST trims, rates 20 mpg city, 23 mpg highway, and 21 mpg combined. That's an average of 1 mpg more than the 4.3-liter V6 found in last year's mainstream, lower-trim pickups, which made do with two fewer forwards gears (six, to the 2.7's eight). Still, the new mill beats the old one by 25 hp and 43 lb-ft of torque.
Moving up to GM's 5.3-liter V8, optional on both 2.7L trims, brings additional horsepower and torque, at the expense of two fewer MPGs in combined driving.
Luckily for The General, adding four-wheel drive to the 2.7-liter models doesn't cause an embarrassing dip below 20 mpg. The EPA rates the 2.7L/4WD models at 20 mpg combined, 19 mpg city, and 22 mpg highway - a combined drop of 1 mpg compared to the 2WD model. Compared to 5.3L/4WD models, the four-cylinder beats it by 2 mpg when equipped with the same eight-speed tranny, or 3 mpg if the V8's bolted to the low-rent six-speed.
The top-flight 6.2-liter V8, when equipped with four-wheel drive, also sees a 3 mpg difference between it and the 4WD 2.7L.
As we told you before, Ford and Ram's base V6 engines offer a slight edge in fuel economy, though the 2.7L handily trounces the 3.3-liter Ford V6 in terms of power. The GM's two main rivals also narrowly edge out the 2.7L's tow rating of 7,200 pounds. Ford's 3.3-liter tops out at 7,700 pounds, while the 3.6-liter Ram is rated for up to 7,730 lbs.
a version of this report first appeared on thetruthaboutcars.com
