Failed Emissions Test
1990 Astro (Z motor) mostly original @ 343,584 miles (552,944.8488960001 Canadian)
Before the test:
Replaced all plugs (3&5 were completely crusted over all others were clean).
New AcDelco O2 sensor.
Changed oil (put in 20W50 (the usual) and 1 bottle of No Smoke/No Leak) (Oil PSI is waaaay up there now.)
Set timing 2-3* after TDC ( I was having bad pinging/knocking).
Ran 1 whole can of Seafoam thru a vac line.
Put 3 cans of Seafoam in the tank with premium grade gas.
Ran the tank out and refilled with premium gas for the test.
Engine was at normal temp.
25/25 Test
Item / Allowed / Actual
HC / 184 / 205 fail
CO / 2.29 / 0.28
NO / 1195 / 247
CO+CO / 6.0min / 14.6
RPM / 2500 max / 1300
50/15 Test
HC / 188 / 207 fail
CO / 1.69 / 0.36
NO / 1300 / 269
RPM / 2500 max / 1327
Ya'lls thoughts ????
Before the test:
25/25 Test
HC / 184 / 205 fail
CO / 2.29 / 0.28
NO / 1195 / 247
50/15 Test
HC / 188 / 207 fail
CO / 1.69 / 0.36
NO / 1300 / 269
