1 - 5 of 5 Posts
Since my Service Manuals are on Backorder I am going to post this here.
I am looking for a way to tap into the vehicle electrical system for my Radar Detector. I'd need Ground and Run/Crank lines (Run/Crank is 12 volts when the ignition is in Run, but typically 9 Volts or less when the vehicle is not in run.
My direct question is, on the Corvette center stack what is the Radio or HVAC using for power? As in what "turns" on the displays when you put the car in Acc or Run, as I'd like to tap into that if there is no easy way to get to the Run/Crank line.
Obviously I'd need a close ground wire as well. Still trying to get everything in order before it arrives you know...
Thanks!
1 - 5 of 5 Posts
