1 - 9 of 9 Posts
Take the picture below and modify it any way that you want. Change colors, looks, background, etc...
The changes can be serious or silly. The changes don't have to make the car more desirable, they just have to make it different.
You are showing off your creativity and your chopping skills.
You must use the original picture as your starting point. Try to keep some semblance of the original pic.
You can make up to 2 entries! But if you do, they have to be significantly different from each other. Please send me final copies only. NO revisions after entry. Once you've entered, that's your entry.
If more than 20 entries are received, I might not use "2nd" entries. So please indicate which one you prefer, in case of that scenario.
Chopping is anonymous!:
Do NOT post your images here in this thread. Instead, E-mail them to: [email protected].
Do not send a link to the picture. Send the picture itself. Please send it in JPG format. Please do not write your name anywhere in your picture.
In your e-mail (but not your picture) please include your user name, even if you think that I know who you are.
You have until Thursday at Midnight to submit your entries, so there is no need to rush right away. Quality takes time. Voting will start on Friday.
Same rule in effect. If you enter, you MUST vote. Contestants that do not vote will be penalized.
Here's the pic to modify:
Re: Current Contest #138: Olds Recon
jonboy78 said:
its the prototype for the acadia - why didn't CHEVY get one of these if the original was an OLDS concept?????
Because 3 is enough!!! GM was able to keep them fairly separate, throwing a Chevy into the mix would have screwed it all up.
looks like a Vue and Acadia got busy. very low-res
i most likely won't be participating in this one, got a big paper to work on, i'll give someone else a chance at the No.1 spot ;).
Ahh, before the days of high-res digital photography. My favorite part is the fridgidare front end.
That rear tire sticks out A LOT!
Discussion Starter · #9 ·
Extended until tonight at midnight!
Not enough entries received.
Even if your skillz aint LEE7, post your entry. This week you can win!
1 - 9 of 9 Posts
