1 - 7 of 7 Posts
I was looking to clean the MAF on my dads 2002 Suburban. Yesterday I took a look at it and couldn't figure out how to get to it, and how to unplug the connector into it. Any help?
Mass Airflow Sensor/Intake Air Temperature Sensor Replacement
Removal Procedure
Important: Take care when handling the mass air flow/intake air temperature (MAF/IAT) sensor. Do not dent, puncture, or otherwise damage the honeycell located at the air inlet end of the MAF/IAT. Do not touch the sensing elements or allow anything including cleaning solvents and lubricants to come in contact with them. Use a small amount of a non-silicone based lubricant, on the air duct only, to aid in installation. Do not drop or roughly handle the MAF/IAT sensor.
  1. <LI type=1>Remove air intake resonator. Refer to Air Cleaner Resonator Outlet Duct Replacement . <LI type=1>Disconnect the MAF/IAT sensor electrical connector. <LI type=1>Loosen the clamp securing the MAF/IAT sensor to the air cleaner housing.
  2. Remove the MAF/IAT sensor from the air cleaner assembly.
Installation Procedure
Important:: The embossed arrow on the MAF/IAT sensor indicates the proper air flow direction. The arrow must point toward the engine.
  1. <LI type=1>Locate the air flow direction arrow (2) on the MAF/IAT sensor.
    <LI type=1>Install the MAF/IAT sensor on to the air cleaner housing. <LI type=1>Tighten the clamp securing the MAF/IAT sensor to the air cleaner housing. <LI type=1>Connect the MAF/IAT electrical connector.
  2. Install air intake resonator. Refer to Air Cleaner Resonator Outlet Duct Replacement .
Removal Procedure
  1. <LI type=1>Loosen the clamp and separate the duct at the mass air flow/intake air temperature (MAF/IAT) sensor. <LI type=1>Loosen the clamp and separate the duct at the throttle body. <LI type=1>Remove the radiator inlet hose clip from the duct.
  2. Remove the air cleaner outlet duct.
  1. <LI type=1>Install the air cleaner outlet duct to the throttle body and MAF/IAT sensor. <LI type=1>Tighten the clamps at the throttle body and the MAF/IAT sensor.
  2. Install the radiator inlet hose clip to the duct.
Removal Procedure
Important: Take care when handling the mass air flow sensor/intake air temperature (MAF/IAT) sensor. Do not dent, puncture, or otherwise damage the honeycell located at the air inlet end of the MAF/IAT. Do not touch the sensing elements or allow anything including cleaning solvents and lubricants to come in contact with them. Use a small amount of a non-silicone based lubricant, on the air duct only, to aid in installation. Do not drop or roughly handle the MAF/IAT sensor.
  1. Hello there, This procedure was a big help for my cousin. I am helping him to clean his MAF, i have copied the procedures that you have posted here and gave it to him. Probably that will make his work a lot easier.
I've used rubbing alcohol on a Q tip though during my last auto parts store trip I've seen a spray for it
I've used that (in a red can; made by CRC) with success. Electronics cleaner will work fine as well.
BTW...
Sorry, I couldn't resist.
1 - 7 of 7 Posts
