1 - 9 of 9 Posts
My 2002 Chevy Venture's passenger side rear window motor seems to have detached from the window clip. When you hit the toggle type button, a motor rotates the window outwards to open it. When the other side of the button, the motor rotates it back inside. Somehow, the connection, which seems to be a ball and socket connection came apart and they don't seem to snap back in place.
What do I need to buy (parts to order, etc.) and how do I fix the problem? Does anyone have a link to help me w/instructions?
Discussion Starter · #2 ·
Thanks for the replies, but as I mentioned, my problem is with the rear window (the furthest window back that opens outward and doesn't include a door). Located next to the rear folding seat bench.
Body Side Window Actuator Replacement
Removal Procedure
  1. <LI type=1>Remove the rear corner upper garnish molding. Refer to Upper Rear Trim Finish Panel Replacement in Interior Trim.
    <LI type=1>Disconnect the electrical connector from the rear quarter window actuator. <LI type=1>Remove the rear quarter window actuator retaining bolts.
    <LI type=1>Remove the bearing bushing retaining screw. <LI type=1>Remove the actuator from the vehicle.
  2. To separate the rear quarter window actuator from the bearing, place the rear quarter window actuator on a shop bench and disassemble by removing the pin from the latch bearing.
Installation Procedure
  1. <LI type=1>Assemble the bearing to the rear quarter window actuator by installing the pin. <LI type=1>Install the bearing bushing retaining screw.
    Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
    <LI type=1>Install the rear quarter window actuator retaining bolts. Tighten
    Tighten the bolts to 10 N·m (89 lb in).
    Tighten the bearing bushing retaining screw to 2 N·m (18 lb in).
    <LI type=1>Connect the electrical connector to the rear quarter window actuator.
  2. Install the rear corner upper garnish molding. Refer to Upper Rear Trim Finish Panel Replacement in Interior Trim.
Tools Required
J 38778 Door Trim Pad Clip Remover
Removal Procedure
  1. <LI type=1>Using J 38778 remove the upper seat belt anchor bolt from the belt guide loop. Important: Use care to not break the locating tabs on the quarter trim when removing the back body pillar trim.
  2. Remove the back body pillar trim from the vehicle.
  1. <LI type=1>Install the back body pillar trim by aligning the trim with the locating tabs on the quarter trim. <LI type=1>Align the retainers in the holes and push to secure the retainers. Notice: Refer to Fastener Notice in the Preface section.
  2. Install the upper seat belt anchor bolt to the belt guide loop. Tighten
    Tighten the bolt to 43 N·m (32 lb ft).
Discussion Starter · #7 ·
Removal Procedure
I think this is just what I was looking for. Doesn't look too difficult. Luckily, I have a $500 gift card from the dealer I bought the Venture from (I can use it for parts, too).
Discussion Starter · #8 ·
I purchased the motor and when I took it out of the box (and compared it to the motor in my vehicle, it looked like my motor was in good working order. I just needed the clip attached to the window. I ordered it (considerably less expensive than the motor) and tried to take out the existing clip, but the phillips screw is so tight, I ended up messing up the head of the screw. Any ideas on how I can take it out? Screwdriver keeps slipping now. Can I use an easy out tool w/my drill?
1 - 9 of 9 Posts
