I just bought a aveo, heres the issue, i set the digital clock then when i shut the car off then go to start it again sometimes the clock is reset to 1:00 .. does not happen all the time and i have checked the fuses all are ok, tapped the clock to see if it would reset and no... it just resets as i said when the car is started.. radio is fine and the fuse runs both radio and clock .. im thinking its in the clock area maybe a loose connection.. i am taking it in so ill keep you posted on what they find incase anyone else is having this issue...
PS this is an ok car.. cheap and very good on the fuel .. happy with it so far
