Has anyone heard what type of front drive axle is in the k6500hd ?
Interesting! The sketchy rumors I have heard so far say the 8+L engine would be for medium duty trucks, not pickups.GM is working on a new gas engine displacing a minimum of 8L for the 2500/3500 -being that Navistar has ties to PSI, I wonder if the 8.8L gasser will see its way under the MD hood?
https://www.psiengines.com/whatwedo/on-highway-engines/
Agree.Interesting! The sketchy rumors I have heard so far say the 8+L engine would be for medium duty trucks, not pickups.
Agree.
If GM does offer a larger than 6.6L for HD/Medium Duty trucks, would think it would be closer to 7.4L than over 8.0L and may not even need that if Gas/Hybrids start to become popular in HD/Medium Duty to replace Turbo-Diesels.
Strong Gas/Hybrids can run as EV's in urban areas and fall back on their Gas ICE for range and extra power along with job site Electric Power Generation and Ford is already heading in that direction and many will follow since few Commercial Fleets are going to risk Range issues with EV Trucks and too large of a Gas Engine will use more fuel than needed in a Strong Hybrid system, even the 6.6L may prove adequate for most users in a Strong Gas/Hybrid.
GM could also add a S/C, Turbo or Twin Turbos to the 6.6L for more power and use in a Strong Gas/Hybrid and could use the new 3.0L I-6 Turbo-Diesel for a Strong Diesel/Hybrid system for HD/Medium Duty to replace larger Turbo-Diesels.
IMHO a LOT of the interest in "spark ignition" engines is OVER MAX UPTIME for example SCHOOL BUSSES where a breakdown is WORSE then the fuel cost so BIG and simple IS THE name of the game and the ROUSH V10 / PSI BIG BLOCK are port injection enginesAgree.
The 8.8L is an interesting engine for Medium Duty use since it has a broad torque curve and "Diesel Like" low end torque, and as a bonus can run on LPG and CNG for lower CO2 levels in urban area Fleet use.Thankfully GM does not have the final decision here. The 6.6 gasser is for light duty use only (2500/3500). The 8.0L+ gasser will be the minimum to meet themedium duty needs.
The 8.8L that PSI uses would be ideal.
It wont be a light duty mall cruiser engine like a GTDI or tiny diesel.
