1 - 12 of 12 Posts
Discussion Starter #1
2005 Chevrolet Cobalt
GM tries to convince us that 'it’s different this time.'
BY PATRICK BEDARD
July 2004
The aging Chevrolet Cavalier, born in 1982, will be replaced this November by the Cobalt, and Chevy has been so eager to tell us about this new line of front-drive coupes and sedans that it offered the following deal: If we’d hold off writing about our “driving impressions,” we could have seat time in a few engineering mules and talk techno with key Cobalt engineers.
“Bring it on,” we said, and checked in at GM’s desert proving ground in Mesa, Arizona. The menu included two black 140-hp Cobalt sedans that were about 90 percent baked and a white 170-hp coupe that was more like 80 percent.
A little background: The Cobalt is built on GM’s Delta platform, which was new with the Saturn Ion in 2003. Uh-oh! An early Ion proved to be amazingly durable in our 40,000-mile long-term test (March 2004). It was also a rackety little ******* of a four-door that our road-test editor passed around to staffers as penance for past offenses. The Cobalt has a lot to live down with us.
Now the post-drive synopsis: The Cobalt has been to charm school. That’s a fact, not an impression, so we can blurt it right out.
When we mentioned our Ion misgivings to Doug Parks, Cobalt chief engineer, he groaned. He knew everything, because he’s been 30 months on the job trying to fix all of those . . . well, GM cheaped out on its first Delta. You know the story. Cheap R Us has been GM’s business plan since the Cavalier was young.
But no more, Parks and others assure us. He points to the comprehensive arrangement of seals around the Cobalt’s doors. He nods toward a large and deeply sculpted plastic cover over the Ecotec four, backed by noise-eating foam. He tells of the laminated steel fire wall and cowl plenum, new since the Ion. He describes the special Cobalt tires that have just the right combination of stiffness in the sidewalls and damping in the tread to achieve sharp steering response and low noise. They cost 0.3 to 0.4 mpg of fuel in EPA mileage, but they please the driver.
Yeah, right. It’s easy to dismiss this pre-preview tub thumping for what it is, GM’s attempt to manage the news. Moreover, our record on these pronouncements has some dents. We were impressed by the Chevy Vega in a 1970 drive of engineering cars much like this Cobalt jaunt. You may even remember our 15-page hallelujah following the preview of the 1980 Chevy Citation, Pontiac Phoenix, etc., line of X-cars. Boy, did we do a butt plant on that prediction!
But things are different this time. (Yeah, right—Ed.) GM has an evangelist for good cars—Bob Lutz—and he has a vice-chairman’s clout. In so many words, Parks says Lutz told engineers not to hold back on the good stuff and how they’ll get that money back and more in reduced rebates.
Our noisy Ion didn’t have the cast alloy oil pan that stiffens, and therefore quiets, the engine’s structure. It didn’t have the stiffened transmission attachment, either. Actually, the trans now bolts to the block and the pan. There’s a low-noise tensioner for the cam-drive chain. Even the oil pump is being finessed to damp a pulsation in the bypass port. The list goes on.
Lutz says being competitive isn’t enough. The Cobalt has to be better than competing small cars to get the market to notice.
Things are different now in another way. Chevrolet is no longer trying to cover the whole bottom of the market with one model. It has the Korean-made Aveo to serve up low, low prices, allowing the Cobalt to move up to the cream of the skinflints.
They get a package that’s big for the class at 180.3 inches overall for the four-door, about halfway between the shorter Toyota Corolla and the longer Cavalier. The exterior is a yawner, one more “universal small sedan,” but the interior is a mini-Lexus in its shapes, tones, and textures. Chrome touches are back, in the bezels and door handles.
The looker of the family is the coupe, with its smartly curved rear glass and cute butt punctuated by four round taillights. The standard engine for both is a 140-hp, 2.2-liter Ecotec four. Opting for the SS version gets a bored-and-stroked Ecotec with variable cam timing, giving 170 horses from 2.4 liters. It would have been cheaper to use the same balance shafts in both engines, at a small sacrifice in smoothness. But, no, that’s not the Lutz way.
There will be an SS Supercharged coupe, too, with an intercooled huffer on a 2.0-liter engine promising 205 horsepower at 5600 rpm.
So we’re cautiously optimistic. The rear suspension is a trailing-arm arrangement braced by a twist beam, similar to what VW has been using in small cars since the ’70s Rabbit. Parks told us of his mission to discover why his guys couldn’t match VW’s way of “enveloping the bumps.” Finally, they found the secret by cutting apart a Jetta’s trailing-arm bushings. They’re exotic fluid-filled, two-chamber hydraulic dampers. And they’re expensive! GM bean counters would never okay the cost. Everybody knew that.
But this is the Lutz era, and the Cobalt will have the magic bushings. Could that luckless Ion have been GM’s low point?
2005 CHEVROLET COBALT
Vehicle type: front-engine, front-wheel-drive, 5-passenger, 2-door coupe or 4-door sedan
Estimated base price: $15,000–$20,000
Engine types: DOHC 16-valve 2.2-liter inline-4, 140 hp, 150 lb-ft; DOHC 16-valve 2.4-liter inline-4, 170 hp, 170 lb-ft; supercharged and intercooled DOHC 16-valve 2.0-liter inline-4, 205 hp, 200 lb-ft
Transmissions: 5-speed manual, 4-speed automatic
Wheelbase: 103.3 in
Length/width/height: 180.3–180.5/67.9/55.7–57.1 in
Curb weight: 2650–3200 lb
C/D-estimated performance:
Zero to 60 mph: 6.5–10.2 sec
Standing 1/4-mile: 15.0–17.7 sec
Projected fuel economy:
EPA city driving (C/D est): 22–24 mpg
EPA highway driving (C/D est): 29–32 mpg
Link to the article below:
http://www.caranddriver.com/article.asp?se...article_id=8207
That's what you call a "puff-piece," guys. I'm not passing judgment until someone reviews a Cobalt that comes NOT from the factory, but straight off a dealer's lot. Guess I'll have to wait for Consumer Reports.
I actually do remember the X-car early drives. Even Road & Track was ready to write off Japan and Germany - Detroit is back! - because the Chevy Citation was now the best car ever built. But Detroit was not back. The Citation was a load of crap. And the writers were humilated by having been taken in by cars that were far better than the cheap junk they eventually produced.
Never has a manufacturer ever so successfully pulled the wool over journalists' eyes. Ever. About any kind of product. I bet a lot of journalists remained pissed at GM for years. Might the humiliation of the scribes that followed those ride-drives have colored their perceptions of GM products for years to come?
Do the math: maybe a few more Detroit-mobiles might have gotten more flattering reviews if they hadn't pissed off the press. Theyd have saved their reputations, while selling a bunch more cars, and making a bunch more money.
Just think what that cheap deception might have cost in the end.
"Lutz says being competitive isn’t enough. The Cobalt has to be better than competing small cars to get the market to notice"
FINALLY! Common sense!
Too bad they didn't use it on the CSVs... (well, they still have some months yet...)
Let's hope this philosophy extends to all GM cars.
Make it better than the competition, and you wont NEED rebates
The Cobalt's styling is sooo anonymous. A lot of people on here are expecting the Cobalt to perform some miracle for GM, but guess what? It's not gonna happen. I think it will do OK sales-wise but GM could have done so much more. Why does chevy even need the Cobalt? They have all those rebadged Daewoos. How many small cars does Chevy need?
Daewoos are subcompacts. The Cobalt is in the compact class. Correct if wrong.
Originally posted by 91fairladyZ+Jul 18 2004, 02:16 AM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (91fairladyZ @ Jul 18 2004, 02:16 AM)</td></tr><tr><td id='QUOTE'> <!--QuoteBegin-Bmw_Kid8888@Jul 17 2004, 08:36 PM
Daewoos are subcompacts. The Cobalt is in the compact class. Correct if wrong. [/b][/quote]
Umm,Here are all the Daewoo's...
Chevy Aveo/Suzuki Swift+ = Subcompact
Chevy Optra/Optra 5 = Compact
Chevy Epica/Suzuki Verona = Midsize
The Civic and Corolla are exciting? Even Ford dulled down the Focus. The Cobalt looks the best out of all 4 of them. Also, dont forget that thrill of a car, the Neon.
I dont think it will pull off anything magical, but It will be a big step in the right direction for GM. The compact car is a large and expanding market. With the Aveo in, the Cobalt can move up market and grab more of an upscale look and feel when the Aveo grabs the low-end.
Originally posted by Bmw_Kid8888+Jul 17 2004, 07:27 PM--></div><table border='0' align='center' width='95%' cellpadding='3' cellspacing='1'><tr><td>QUOTE (Bmw_Kid8888 @ Jul 17 2004, 07:27 PM)</td></tr><tr><td id='QUOTE'>
Chevy Epica/Suzuki Verona = Midsize[/b][/quote]
Welcome to Canada, where apparently we all love small cars. In the US the only rebadged Daewoo is the Aveo.
1 - 12 of 12 Posts
