1 - 2 of 2 Posts
i have a 2000 Grang Am GT coupe. i took it to get inspected about a month ago. since then there are 2 things not working properly.
1. when i take it out of park, the doors will not lock. when i put in park and tunr the car off, they will not unlock. i read the manual and it says to hold the lock button down until you here chimes, but i dont get diddly squat. no chimes at all
2. my gauges dont do their self-test thing when i turn the car on. for instance the speedo should go from 0 to 150 and back to 0 again. doesnt do that anymore.
I tried disconnecting the battery for a while to see if that would reset something somewhere, but to no avail. i dont know if they are any fuses or something that controls these things. any help would be appreciated.
There is a fuse on the LH side of the dash (J 15 amp)
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=614586&pubCellSyskey=62019&pubObjSyskey=614586&from=sm&cellId=62019#ss1-614586">LH IP Junction Block
Fuse
Rating
Description
AIR BAG
10A
Sensing and Diagnostic Module (SDM)
BFC BATT
10A
Body Control Module (BCM)
DR LOCK
15A
Door Locks/Relays
HAZARD LPS
15A
Hazard Lamps/Switch
IPC/BFC ACC
10A
Instrument Cluster; Body Control Module
IPC/HVAC BATT
10A
Instrument Cluster; Heater A/C Control Assembly; Data Link Connector
PCM ACC
10A
Powertrain Control Module (PCM)
PWR MIRROR
10A
Power Mirrors/Switch
CIRCUIT BREAKER PWR SEAT
25A
Power Seat
RADIO ACC
10A
Radio
RADIO SW
2A
Steering Wheel Radio Switches (Pontiac)
STOP LPS
20A
Stop Lamps/Brake Switch
TRUNK REL/RFA/RADIO AMP
10A
Rear Compartment Lid Release Relay; Remote Control Door Lock Receiver (RFA); Audio Amplifier
TURN LPS
10A
Turn Lamps/Hazard Switch
1 - 2 of 2 Posts
