It's within the realm of possibility. C7 does it in 3.7-3.9 seconds, the ATS-V having a TTv6 would have more torque on the low end. And it appears to be able to hit 60 while still in 2nd gear.I got ~3.4 seconds for 0-60, and ~7.7 seconds for 0-100...
WOW.
That would be incredible and confirm "killing" the M3/M4.I got ~3.4 seconds for 0-60, and ~7.7 seconds for 0-100...
WOW.
Ha! I was thinking the same thing. Maybe a CTS-V?Camera car was pretty quick
Most likely, Gen 2 or Gen 3Ha! I was thinking the same thing. Maybe a CTS-V?
In a C&D comparison test, the C6 Corvette ZR1 did 0-60 and 0-100 in 3.4 and 7.7 seconds respectively. The ZR1!It's within the realm of possibility. C7 does it in 3.7-3.9 seconds, the ATS-V having a TTv6 would have more torque on the low end. And it appears to be able to hit 60 while still in 2nd gear.
That E-DifIn a C&D comparison test, the C6 Corvette ZR1 did 0-60 and 0-100 in 3.4 and 7.7 seconds respectively. The ZR1!
I can't wait to see the numbers on this thing.
It's definitely sub 4 seconds 0-60, and by a good margin.I got ~3.4 seconds for 0-60, and ~7.7 seconds for 0-100...
WOW.
The numbers show that it can keep up with a C6 ZR1...It's definitely sub 4 seconds 0-60, and by a good margin.
The numbers show that it can keep up with a C6 ZR1...![]()
M4 only does it in 4.1 seconds.The numbers show that it can keep up with a C6 ZR1...![]()
Well, 0-61 is in 3 point something...It probably isn't 3.4s 0-60 unless it's severely underrated by about 150 hp and lb-ft of torque OR magically lost half a ton OR if its governed by some strange new type of physics.
It still sounds and clearly goes like a beast, however fast it may be.
