1 - 3 of 3 Posts
I have a 98 Camaro w/V6. My problem is that, When I arm the system in about
10 sec or so. The Alarm sounds. If I lock the doors from the inside using the door
lock button. The Alarm does the same, it goes off. The only way I can lock the doors without the system going off. Is for me to lock the 2 door individually.
At first I thought one of the doors or that hatch was open. But, thats not the case.
Everything else seems to be working fine.
Any help would be greatly appreciated.
Thanks,
Howie
The scanner you are referring to, is that the same one mechanics use when the trouble light comes on. Because my brother is a former mechanic and he has one.
I'm trying to avoid having to take the car to the dealer.
Thanks for you input
1 - 3 of 3 Posts
