I have got a 2002 silverado 4x4 4.8L. I am in the process of fixing the leaky front differential. It has been leaking where the axles go in. I have the whole differential out of the truck and on the workbench.
I knocked out the passanger side axle shaft easy enough, (I hope thats the proper method), but the drivers side shaft is staying put. I am using a hammer and long punch to try and pop it out. I don't want to hit it to hard and harm the unit, is this the proper way to remove the shorter/drivers side axle?
Also, should I be replacing the bearings on these shafts?
The truck has 150,000 kms mostly highway, lots of towing, thanks, Pete.
