allante, yes, slipped my mind lol ! white....alante?
There should be a jump start post under the hood. It will have a red cap on it. Then take the black lead and hook it on any ground.Where is the battery hidden and how do you access it ? Cannot jump start it under the hood !
thanks but I tried that, can't charge or jump battery....There should be a jump start post under the hood. It will have a red cap on it. Then take the black lead and hook it on any ground.
seems like I looked there per a 91' manual, '93 is different I believe.....The battery is located behind the passenger seat on the side of the cargo platform. Slide the carpeted side panel forward to expose the battery. I had to replace the battery in my 91 last week.
TYIAI believe the location is the same for all years. Try opening the trunk pass-thru and pushing the side panel forward from the back edge. That's what I had to do to help it slide back in all the way. It's easy for the sliding panel to get off the right track and get jammed by someone installing it.
actually there were two panels, first the rear cover which exposes the rear of sliding panel. Thanks a million fiat !I believe the location is the same for all years. Try opening the trunk pass-thru and pushing the side panel forward from the back edge. That's what I had to do to help it slide back in all the way. It's easy for the sliding panel to get off the right track and get jammed by someone installing it.
I wish there were, with factory manuals !Isn't this available on line? a car repair site?
