Any of you guys modified yours? I am getting ready to install a 3.4 inch pulley. Also going to port the throttle body and maybe the supercharger too.
Of course, torque management pretty much negates this power increase.GPGTX said:also the 2005 3800 is a series 3 motor rated at 260 hp
easy solution for this. a reflashed pcm.dav305z said:Of course, torque management pretty much negates this power increase.
No. You can leave part ot the box in place or remove it altogether... tie wrap it in place with a bit of padding underneath or purchase a small tray to mount it in. I think there is actually a GM truck part that works well for mounting it... you could try going to clubgp.com and search for "PCM tray"98Park said:I have a 98 Ultra i want to put a cone filter on, unfortunately the airbox also houses an engine computer, does anybody know if leaving the box open will damage the computer or what i can do?
I was saying that because we had to change both the serpentine belts and the supercharger belt in my bros 96 Riviera. Getting the belts off was easy. rethreading all the belts on the other hand was a different matter and it took 2 days to re thread both belts. Thats what i meant by my statement. the pulley changes are not that bad but the belts can pose a challengeI did play with the belts on a L67 and I thought it was a cakewalk. I mean all ya got to do is move the springy thing, then just slip the belt around and you're done. Just need a decent wrench of some sort to hold the springy thing.
The problem on the Riviera is the belt goes around the engine mount, meaning you have to remove the mount and prop up the engine to get the belt out. Engineers...I did play with the belts on a L67 and I thought it was a cakewalk. I mean all ya got to do is move the springy thing, then just slip the belt around and you're done. Just need a decent wrench of some sort to hold the springy thing.
Lot's of help here... www.regalgs.orghey guys...im looking to get a little more speed out of my 2003 Buick Regal GS 3.8 S/C and was wondering if someone can guide me into the right direction. after reading a few posts here, i was wondering can the same thing apply to mine that Dav done to his? Dont want to do much but that sound like something i can do. thanks
