You can quite wondering! How about we get back to the technical question proposed about the cause of the timing chain problems.
Lets quit trying to ignore it and address it. What do y'all think? Is it the new small (7.7mm) size that is the cause of the failures or what?
Well, lets search for "
timing chain problems " and study the Ford, Toyota, Nissan, and VW responses that dominate the search for a clue as well as the frequently mentioned BMW, MBs, Audis and the less frequently mentioned Suzukis, and Mitsubishis.
First page looks like this.
1.
HELP-Timing chain problems - Ford Forums
We have been told that it is the timing chain. Here is the problem, Everyone we talk to tells us that there is a different number of timing chains on our ...
www.ford-forums.com › ... › Ford Explorer - Cached - Similar
2.
VWVortex.com - Finally ... a sound clip of timing chain noise
yeah i never thought that i had timing chain problems until i read this thread and it matched the strange noise/shaking i have ...
forums.vwvortex.com/showthread.php?1127339 - Cached
3.
HAS ANYONE HAD TIMING CHAIN PROBLEMS? | Nissan Quest Forum Community
Oct 7, 2009 ... Luckily for me I got my problem fixed. It wasn't the timing chain for me. I had some known as spark knocking/rattling AKA "pre-detonation". ...
questdriver.com › ... › 2004 - 2009 Nissan Quest - Cached - Similar
4.
Timing belt - Wikipedia, the free encyclopedia
In the internal combustion engine application, the timing belt/chain ... This is not a problem unique to timing belts since the same issue exists with all ...
en.wikipedia.org/wiki/Timing_belt - Cached - Similar
5.
DIY: Replace Your Timing Chain
One of the internal working parts that wear is the timing chain and timing sprockets. ... As the timing chain and sprockets wear, this precise timing of the valves gradually ... No-Start ProblemsJump Start a CarAutomatic Transmission ...
autorepair.about.com/cs/doityourself/a/aa042702a.htm - Cached - Similar
6.
Timing chain problem with Nissan sentra - CNET Car Tech Forums
Jun 13, 2005 ... Car Tech: Timing chain problem with Nissan sentra - Read Car Tech discussions and get tips and advice on this topic and others on CNET ...
forums.cnet.com/7723-7811_102-108963.html - Cached
7.
Videos for timing chain problems
sr20 timing chain problem
10 sec - Jun 22, 2009
Uploaded by natedrake88
youtube.com
CHEVY ENGINE REBUILD CAMSHAFT TIMING CHAIN ...
5 min - Feb 21, 2008
Uploaded by ronieboy44
youtube.com
8.
What causes timing chain problems? - Yahoo! Answers
Apr 12, 2010 ... The timing chain "stretches" over time and the gears they ride against wear down, causing slack in the chain and causing the base timing at the ...
answers.yahoo.com › ... › Cars & Transportation › Maintenance & Repairs - Cached
52 plate Vauxhall Vectra C Sri 2.2 timing chain problem? - Sep 20, 2009
1997 Ford Explorer Rear Timing Chain Tensioner Problems ... - May 1, 2009
95 S10 timing chain problem? - Sep 11, 2008
More results from answers.yahoo.com »
Get more discussion results
9.
Timing Chain Slack Test
There is a very simple check for a loose timing chain due to a broken tensioner, worn gears, ... A compression test will also reveal timing problems. ...
www.misterfixit.com/chanslop.htm - Cached - Similar
10.
Signs of Timing Belt Problems | eHow.com
Signs of Timing Belt Problems. Timing belt breakage is one of the most common causes of cars breaking down. By having an idea of what a timing belt is and ...
www.ehow.com › ... › Replace Honda Timing Belts - Cached - Similar
Searches related to timing chain problems
nissan altima timing chain problems
ford explorer timing chain problems
timing belt problems
timing chain replacement
timing chain change
honda element timing chain
engine timing belt
bmw 740 timing belt
Of course, as we can see, there are timing belt 'problems' to consider as well.......
Oh, and uh, let's try and determine how many have ****ty parts problems from Aisin or some other partially Toyota owned subsidiary besides the owner and lube product generated problems.
Worth noting, in the first one hundred search items ( ten pages x ten listings) outside of GMI the 3.6 is
mentioned once - by one of our very own but on another forum board in the as expected
'stir the pot' fashion.
