Status
Not open for further replies.
1 - 13 of 13 Posts
2015 Silverado almost got me killed because I cannot accelerate past 98 MPH have called GM several times and have gotten runaround dealership says they cannot do anything I must call GM. Maybe time to get a lawyer involved clear case of being mislead almost causing major freeway accident had I not gone out through meridian. $ 50,000.00 and the truck wont pass 98 and GM wont solve issues and respond in a timely manner, have been calling for the last 2 weeks and only owned the truck for 3-weeks
· Super Moderator
Is it speed limited to 98? Why in the hell are you going 98 on a regular basis in the first place? Isn't the fastest road in the US limited at 85?
The fastest speed allowed on the freeway is irrelevant, I was hanging about 80-85 MPH when I got boxed in and the semi-truck on my right started to move into my lane I could not back off due to the 2-semis behind me trying to pass the slow one I was trying to pass which is why the only safe location was the meridian. The speed I drive is none of GM's business but mine anyway and GM has clearly been misleading with a speedometer that goes to 140 MPH. Had I been foretold of the top end, I might have never gotten into that situation because I would have known that it would not get-up and go when needed. 35+ years and many thousands of miles of driving GM products and I can cite many situations where acceleration well beyond the speed limit is required to avoid accidents. Gratefully the truck handles well enough that it handled the dirt meridian area very well.
· Super Moderator
And 98 wasn't fast enough to pass a semi truck?
Something's fishy here. If the truck was wandering into your lane you would've had to go into the median no matter how fast the truck can go.
In any case, almost every non-performance car (and most performance cars) out there is speed limited. Maybe Silverado's is at 98.
· Super Moderator
Also you do realize the speedometers go to 140 because there's this thing called the metric system?
The top speed of the 2014/15 Silverados/Sierras is governed at 99mph with the factory equipped 5.3 V8 & 4.3 V6 on all models.
The top speed of the 2014/15 6.2 V8 models is 110 (governed).
I believe I've read that all 2015 Ford F150 models will be governed at 100, just to give some perspective.
One simply should not be driving a stock pick up above that speed. They are not built for it. And yes, GM does have a right to know how fast you are traveling as it would be them who would get sued in the event of a tragedy. Hence, the speed governors employed by GM & Ford.
Discussion Starter · #10 ·
The 1996, 3500 not owned by my kid and my 2001 3500 dully "both which I still have or can access" will both peg the speedometer. So when did GM or any of the manufactures for that matter, decide that they will limit the vehicle to what a tire manufacture "that they chose" says is as fast as the tire can tolerate. When did GM or any others tell me what tire brand I have to use and fix the speed to their "GM's" choosing of the tire company. They have no idea what tires I am running nor any right to tell me what tires I will run after I purchase the vehicle. To top it all off they "after I have purchased it" they have no right to tell me anything about what I do to or with the vehicle. This is strictly my decision and for them to attempt to limit my choice as to what I do with my equipment is clearly an infringement on my rights.
· Super Moderator
Then remove the speed limiter. A lot of people do it after taking delivery.
Good lord. Nobody's infringing on your rights. It's your car now, do whatever you want with it.
Discussion Starter · #12 ·
So lets see if I have this correct: GM has determined to protect those who do not know their vehicles capabilities and limitations, I am required to comply with something I did not know about, which may or may not put me in harms way and completely disagree with after spending that kind of $ especially after not being told this is a limitation "we" have decided is best for you. "HEIL HITLER" "don't think so".
· Super Moderator
...Yeah we're done here. Go to a performance shop and tell them to remove your speed limiter. If your tires shred and you lose control at 110 MPH or whatever ludicrous speed you need to pass a semi, that's your problem, not GM's.
1 - 13 of 13 Posts
Status
