I purchased a used 2011 Duramax 3500 with only 26000 miles on it. Within my first week I had the Def warning light stating the DEF was of poor quality. I took the truck back to the dealer. They said the tank needed to be replaced. They ordered a new tank, at which time I did not have the use of my $ 45,000.00 truck. But I figured, it happens. I got my truck back, put about 7000 miles on it, and guess what? SAME DEF WARNING. Now this happened two days before taking a trip from Rockford, Il to south Texas. I returned the truck to the dealer. It was there from 12/30/2013 to 1/10/2014. They said they had to order some seals a def injector. During that time they also came up with the need to replace the catalytic convertor. So, I finally get my truck back and plan to take off for south Texas.
WRONG!!!! I get 10 miles from the dealer and the warning light is on AGAIN!!
Now. I own a semi truck and drive over the road. I have lost almost $10,000.00 in revenue because of this issue. I can not go to work while truck is in shop. When I go out I do not know when I will return home. Sometimes it is two to three months. I am single and have no one here to take care of things at home when away.
This is the third strike on the same issue.
I am now turned completely against this truck. I am now afraid to take a long trip as I may end up being towed in to a dealer and have to sit in a hotel for who knows how long for someone to figure out what is wrong with my truck!!!
I have called GM Customer Service and have a case file on this truck, but I am not going to continue to have a vehicle with continuing problems. I have been on a number of forums including this one and have found that this is a normal problem with the 2011 Duramax.
I am to the point where I believe that GM needs to step up and do the right thing.
They need to replace this truck with a new one. Not necessarily a 2014, but a 2013 would be ok. I actually found a 2013 at a dealership in Washington State exactly like mine and it was only $2000.00 more than I paid for mine!
Come on GM. I have been a Chevy person since my first car at 16 years old! I have 2 1973 corvettes. One of which is factory original to the paint and hub caps. Do the right thing! Don't make me turn to a Ford!!
