1 - 2 of 2 Posts
Ok, I'm having an issue with the transmission on my 2010 Equinox. While driving the transmission seems to take itself out of gear and causes me to have to coast to a stop. "Engine is still running at this time." After I stop if I immediately turn the engine off and start it again, I try to shift it won't move forward nor reverse.
After waiting a few minutes and letting the car sit and everything off. I can start it and it will shift and drive for anywhere from 100-500 feet and it'll repeat the issue. There is no gear grinding sounds just a small "whinnying noise"
I'm wondering if there's a linkage issue, solenoid issue? Any ideas I'd greatly appreciated it!
I had a similar issue with a 5L40, it turned out to be a blocked filter. The "whinnying" noise was cavitation from the pump not getting any trans fluid I think.
1 - 2 of 2 Posts
